"obsolete Technology" Lamp
Published
Introduction: "obsolete Technology" Lamp
About: Freelance designer in the making - Nacimos para cambiar el mundo.
This Is a lamp I'm making, originally inspired by an instructable that I can't find right now (edit: found it: https://www.instructables.com/id/Recycle-Old-Light-Bulbs). What I first intended, was to make the same thing only with light. but then, Inspiration stroke me when I tried filling it with water. I decided to make it like an aquarium, only that instead of sand and rocks, there would be pcb's, screws and other electronic parts.
It's looking quite good!
Also, I wanna sell it once I finish, as I'm trying to follow my dreams and become a "freelance designer" ( I already quit my job! I got a month left) do you think I can make it?
here's how I made it:
parts:
- Cylindrical vase
- LED strip
- Some wire
- 12 VCC power supply
- Old incandescent light bulbs
- old/broken/unusable pcb's
- small screws
- various unusable electronic parts
- one or two CD's
What I did:
First I glued the vidicon on the bottom of the base.
I placed all the little pcb's, taking care to place them circuit-side up.
then I filled the vase with water. then I sprinkled the little screws and various parts.
after that, I put in all the light bulbs. I had to tape the CD to keep them down.
you can put the lights any way you like. That's your call.
It's still in progress, so I'll post a full instructable when it's done.
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    5 Comments
    Also, if you do use water, make sure you add something to it to stop it going green and manky and became a "health hazard obsolete technology lamp". Or make it drainable!
    It is drainable :) but I'm still thinking what else can I make. Something more interesting than just water...
    I don't know if you are still working on this but You may be able to use hand sanitizer. I really hope you continue this project because I love the idea. O and I'm not sure if it will work but you could use a large amount of model glue. It should dry clear but it will probably stay gel like for a long time.
    Could one use oil instead of water and then actually wire up the bulbs in the fluid?
    Gee, I don't know. these were all death light bulbs, but you could try that. also, lighting them up with induction or something. Try it!
