Introduction: Old Knife Key Holder
Picture of Old Knife Key Holder
you will need:
-A tool to disassemble your knife (different with every knife)
-A metal file
-A key
Step 1: Step 1 Remove the Blade From Your Knife
Picture of Step 1 Remove the Blade From Your Knife
simply unscrew the screw that holds the blade in and hold on to the screw and handle, the blade is no longer needed.
Step 2: Step 2 Fit the Key
Picture of Step 2 Fit the Key
put the key in the knife handle in place of the blade and file it down until it fits tightly in the handle so that the portion of the key that unlocks the door is inside the handle
Step 3: Step 3 Reassemble
Picture of Step 3 Reassemble
line up the hole on the key with the hole on the handle and screw in the screwthat once held in the blade and you are done. this process can be done to as many things as will fit in the handle.
if you have any notes or improvements please let me know.
smcmasters1 (author)2015-03-08
Have you thought of any ways to reuse the old blade? Also, you could probably take the screws out of the handle and replace them with longer ones if you wanted to put more keys in the handle. As long as you put a washer between each key, I think that would keep them from catching on each other and easier to flip them out.
abaratta (author)smcmasters12015-03-15
thank you for the imput i am thinking of a way to reputpose the blade and when i do i will make an how to
About This Instructable
1,000views
38favorites
License:
More by abaratta:old knife key holder
Add instructable to:
