Introduction: Origami Necklace
this is my second instructable and im gonna show you how to make a origami necklace
(plz comment)
Step 1: Materials
so all the materilas you need are
a toothpick
some 20 cm high pcs of triangle paper
glue
string
and a good pair of hands
Step 2: First
as i said in the materials step you need a couple of triangle pcs of paper
(20-30 cm high and 1/2 an inch wide)
Step 3: Making the Beads
put some glue on the tip of the triangle
Step 4: Roll It Up
now you use the toothpick to roll up the paper to start making the bead once you finished the bead slip the toothpick out and repeat with another piece of triangle paper
Step 5: How It Should Look
if you rolled it up completely it should look like this
now just slip the toothpick out
Step 6:
now just slip the string through the beads,and when you run out of beads tie the ends together
