Introduction: Bucket Light
this is a powerfull and rainproof outdoor light with a cfl
the functional and full variant of it is seen here. an easier hanging variant can be built as well
the way this light is built can be used to rainproof extension cables etc as well
Step 1: Attention
the project uses 110 / 240 V electricity directly from the socket. this amount of electricity is enough to electrocute or set stuff on fire. in addition outdoors can be very wet
the project uses a cfl in outdoors area. cfls may fail with fire and sparks as result of water ingress / condensation or if small insects get into them
by building this project you take the entire responsibility to the consequences on yourself
Step 2: Materials
cfl up to 20 W
light socket
cable (with 2 thin wires)
electrical plug
2 plastic bottles
additions for on ground variant
small bucket
aluminium foil
strong column (steel rail is best)
additions for creativity
colored transparent plastic sheets or colored bottles
permanent markers
wallpapers with wanted overall color
common tools
Step 3: Hats
hat 1 - cut it from a bottle along the bottom of the label
hat 2 - cut from another bottle the top (allmost up to the max width of the bottle)
for hanging lamp - cut some small vent holes near the neck of hat 1. those holes will let out hot air from the cfl (in summer nights the heat may be enough to damage the cfl). hat 2 prevents the rain entering the holes from getting to the electricity
make holes in the caps for the cable
in hanging lamp - at least one of the holes should be tight on the wire to avoid water getting through
in ground lamp - make the holes tight for strength but add a small hole in each cap. the small hole is required to drain water ingress if it happens
in hanging extension cable - make the hole on cap of hat 1 loose (so it can slide on the wire) and cap of hat 2 tight
screw the caps in place and get the cable through. hat 2 is inside hat 1
a larger cfl can be used in the hanging variant if hat 2 is a bit larger and placed outside of hat 1. the vent holes can be made larger too
Step 4: Socket
connect the cable to the socket
fix the cable to the socket if possible or make a knot inside to prevent it from pulling out
slide everything to place. make a knot between the hats
Step 5: Plug
connect the cable to the plug
use the locking feature of the plug or make a knot to prevent the cable from coming out
Step 6: Hanging Variant - Done !
the hanging variant is quite powerfull (20 W cfl)
it gives much upward light though. this light is just wasted and contributes its part to hide the stars from the sky
for the bucket light - hold on !
Step 7: Colors and Shapes
part of a colored bottle or color filter can be added to color some of the light
about 2 - 3 layers of plastic from another bottle are needed to noticably affect light color
you can also use the lord to draw directly on the hat or use aluminium foil as reflector. use an insert from another bottle to hold the foil in place. shapes can be cut into the foil
ground variant - you can stick wallpapers to the bucket (see next step) from inside. they give their overall color to the light
Step 8: Bucket Head
cover the bucket from inside with aluminium foil. dont leave voids - theyll appear as patches of light when it is working
(when washing the bucket i managed to dump all of it straight on a plugged in extension cable _. so i decided to include it as option in the inst too)
Step 9: Ground Pole
stick a pole in the ground and fix the light to it
i used stacked togeter pieces of steel c beams which i found in a construction site. the beams are used to build the core inside light walls
Step 10: Spacer
a spacer is required between the lamp and the bucket. it keeps open vent holes above the lamp and keeps the bucket aligned on the construction
for the spacer cut a big cylinder (from the bottle you made hat 2 of) and push it in hat 1
the construction should now look much like a transparent cardboard box with flaps and a cfl inside
Step 11: Head On
place the bucket on the construction
tie it with a wire to the column so it wont move
in the day it looks much like a construction site hack. i think its quite cool
Step 12: Done !
now the real bucket light is done. enjoy high contrast light without upward light losses
look up and enjoy the sky full of stars !
Keep the Bottle Contest
