also i will give the instructions for a barrel that fits a paint grenade and shoots it 100-200 feet fairly accuratly but you have to use a tippman squadbuster take of the mesh then pull the pin out and make straight instead of bent and slide it down the barrel
a shorter barrel makes it more accurate becuase it is overly poweful with a long barrel and i will get video of it
MPG_0040.MPG648 KB
Remove these ads by
Signing UpStep 1Getting materials
2 3-inch diameter schedule 40 pvc end caps
2 1 1/2 to 3/4-inch reducing bushings the 3/4-inch part threaded
2 metal 3/4-inch pipe nipples
1 3/4-inch ball valve (can get an electric sprinler valve to have an electric tigger)
1 1 1/2-male threaded adapter
1 1 1/2-female threaded adapter
1 1 1/2-inch to 1-inch reducing bushing
1 1-inch to 3/4-inch reducing bushing
1 3/4 inch pvc pipe (watever length you chose but longer makes it stonger to a point)
1 tubeless tire valve
1 thing of pvc cement
1 thing of pvc primer
1 roll of teflon tape
1 0-160 psi gauge (optional if your pump has a psi gauge your fine)
1 t connecter 3*3*1 1/2
Optional(for paint grenade launcher)
1 female 1 1/2-inch adapter
1 1 1/2-inch pve pipe(any length)
The Cannon
40 in barrel
2 in ball value
20 in long 4in pipe for air chamber.
I use dixie cups to hold the paintballs in the barrel but they spread out over a large area 100 ft out.
I had a fire based gun. they suck go air and go long barrels it looks cool and you can shoot farther with practice and arc.
freeze balls and shoot them at people you become very unpopular.
