palindrome song: how to make a song the same forward or reverse (w. lyrics)
Music:
Option 1: play one sound file forward, copy it then reverse it, and then paste it on top of the original
and / or
Option 2: with midi : trigger sounds on a grid display in patterns that are the same left to right as they are right to left. for example, a triangle with an upside down triangle inside of it. It sounds good if the triggers make up notes of a chord. make the samples that are triggered to be sounds that are the same forward or reverse (see option 1).
Lyrics:
say what you want to say, then play it backwards and look for what it says. be imaginitive. for example i tried: "a cycle outside a cycle" and got "look outside, it's light" when I reversed it. paste the first then the reverse (or vice versa =) ) spaced the same time from the center.
it may take a little work on the lyrics, you have to speak/'sing' in between the two phrases. you can apply music: option 1 to the lyrics to help out.
Step 1The challenge is to make it not creepy sounding.
Music:
and / or
Lyrics:
6 comments
Oct 19, 2007. 1:38 PMwingman246 says:
try 'another one bites the dust', my friend tells me it sounds like 'we like to smoke weed' or something like that.
Nov 12, 2007. 3:13 AMmunchman says:
When the chorus is played backwards it sounds like 'it'sf un to smoke marijuana'
Jul 13, 2011. 6:01 PMredorchestra says:
I heard "decide to sell marijuana"
Nov 14, 2007. 1:37 PMwingman246 says:
yeah i knew it had something to do with pot
Feb 22, 2010. 7:41 AMTrainguyxx says:
what do you use to reverse the files?
Oct 15, 2006. 7:23 PMShark500 says:
Or in Hilary Duff's case, http://subliminal.ytmnd.com/, atleast not today | hail this nazi land
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jasonbates
