Paper Water Level Indicator Circuit With Paper Transistor
2,592
5
7
Posted
Introduction: Paper Water Level Indicator Circuit With Paper Transistor
take a paper and penile
HOW TO MAKE PAPER TRANSISTOR
List of material need
1. Paper (any book are note paper )
2. Pencil  (any one )
3. LED  (20 mA  small LED)
4. Wire single strand
5. Sticking tape
6. Battery (6 volt 4.5ah or 12 volt 7ah for best result )
Step 1:
draw a transistor shape using pencil
Step 2:
using pencil fill the shape with dark shade
Step 3:
add LED like an image connect  positive to LED anode and cathode to an paper transistor collector using sticking tape
see video for paper transistor
Step 4:
using pencil draw a ring at base of transistor and fill with pencil shading
Step 5:
please metal glass on top of the ring and connect battery like positive to an LED anode and negative to an emitter of paper transistor
Step 6:
make a  positive extinction like blue wire for level point
Step 7:
now dip a blue wire with out touching metal wall  to a water filled metal glass so the positive trigger is given to the base so LED switch off
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
6 Comments
This instructable is definitely compiled of some seriously misleading info. Please know that Transistors can Transfer Resistance as you use in your argument, but that's not what makes it a transistor. If your word was true then any metal with resistance can be considered transistors.
This is not a transistor, your simply using pencil led as a conductive part of your circuit. It doesnt matter how you draw it, put your contacts in the same parts of the circuit youll have the same results. the very first transistor was built in the 1920's and consisted of two layers of glass sandwiching a thin layer of aluminum surrounded by a semiconductor material. technology is obviously gotten way better but you can't just draw a transistor schematic symbol on a piece of paper and have it work the same way. Refer to the coments people are telling you it really gets too technical to leave in a comment.
'Tis its not a transistor, but a voltage divider... the same way I used to make a variable resistor
Paper and penile???
what is transistor?
its transfer resistance ok cool
