tool list approximate . screwdrivers ph0 did most of it, there security screws to get into machine at the time i just used a slightly mashed flathead,the maching holds together fine if the security screws are not put back(pic on next step)
a scavenged pc power supply
a soldering iron, (if your just doing power you could get away with terminal blocks, or even twisty wire and tape)
wire cutters strippers,
possibly a switch to turn power box on and off
for the fan stuff
some fans
wire
dirty iron and plastic cutting things
nylock nuts and bolts, zip ties 4 holding fans in place
hot glue gun for securing stuff , (its non conductive and lasts for ages its great for making weak solderd bits strong)
optional fan control, switch or a potentiometer or thermostat , i used a temperature control kit, i think i should have gone for a pot insted but its done now.
decoration ,
fablon ,,
allegedly attractive sticky back plastic i used chrome colour
scalpel with new blade
Remove these ads by
Signing Up
Visit Our Store »
Go Pro Today »
I didn't want to subject the motherboard to ant unnecessary stress, Its probably a multilayer board and designed to fail if tampered with, Iike most sony stuff.
The future is in your hands.
lcd tend not to , dont know about plasma.
ps3 model number? may have tiny differences in electrics ,mine cech-2503b.
pc power supply old/ ok. use a process of elimination. let us know how you get along.
the playstation power supply pin numbers are there next to the white connector 1 to 4 these connect to the motherboard by a white plug step3 i left the plug attached to the motherboard step4 and solderd to the wires this saved me the trouble of applying heat to the motherboard and the removal of the metal shielding theres probably numbers under there but the nice white plug and wires provided the nessasary connections.use the defective power box from the ps3 as your guide. there are also 2 more connections without numbers(or the numbers are on the other side of the board)both these connections are housed in a black plastic box on the ps3 power supply they connect to 2 pieces of metal that stick up from the motherboard of the ps3, i think there was a piece of plastic at their base which i attempted to remove with minimal force but in the end i just solderd to the long bits that stuck up and put some heatshrink over to make them safe.use the defective power box from the ps3 as your guide
on the playstation pin (4) acin_det and pin (1)5vsv connect to the purple wire 5volt at 2A from the computer power thing,
pin (2) gnd connects to a black wire
theres 2 metal contacts that stick up from the motherboard ones + and ones - dont mix them up, use the defective power box from the ps3 as your guide
on the playstation psu the 12v connector black plastic bit(not numbed ) goes to a sticky up bit of metal this connects to a black and yellow wire 12volt at 14A
also in the black bit theres a gnd the corrosponding sticky up bit of metal this connects to a black wire,
`ǝɹıʍ ʞɔɐlq ɐ oʇ sʇɔǝuuoɔ sıɥʇ lɐʇǝɯ ɟo ʇıq dn ʎʞɔıʇs ƃuıpuodsoɹɹoɔ ǝɥʇ puƃ ɐ sǝɹǝɥʇ ʇıq ʞɔɐlq ǝɥʇ uı oslɐ
ɐㄣ⇂ ʇɐ ʇloʌᄅ⇂ ǝɹıʍ ʍollǝʎ puɐ ʞɔɐlq ɐ oʇ sʇɔǝuuoɔ sıɥʇ lɐʇǝɯ ɟo ʇıq dn ʎʞɔıʇs ɐ oʇ sǝoƃ ( pǝqɯnu ʇou)ʇıq ɔıʇsɐld ʞɔɐlq ɹoʇɔǝuuoɔ ʌᄅ⇂ ǝɥʇ nsd uoıʇɐʇsʎɐld ǝɥʇ uo
ǝpınƃ ɹnoʎ sɐ ᄐsd ǝɥʇ ɯoɹɟ xoq ɹǝʍod ǝʌıʇɔǝɟǝp ǝɥʇ ǝsn `dn ɯǝɥʇ xıɯ ʇuop - sǝuo puɐ + sǝuo pɹɐoqɹǝɥʇoɯ ǝɥʇ ɯoɹɟ dn ʞɔıʇs ʇɐɥʇ sʇɔɐʇuoɔ lɐʇǝɯ ᄅ sǝɹǝɥʇ
ǝɹıʍ ʞɔɐlq ɐ oʇ sʇɔǝuuoɔ puƃ (ᄅ) uıd
`ƃuıɥʇ ɹǝʍod ɹǝʇndɯoɔ ǝɥʇ ɯoɹɟ ɐᄅ ʇɐ ʇloʌގ ǝɹıʍ ǝldɹnd ǝɥʇ oʇ ʇɔǝuuoɔ ʌsʌގ(⇂) uıd puɐ ʇǝp‾uıɔɐ (ㄣ) uıd uoıʇɐʇsʎɐld ǝɥʇ uo
ǝpınƃ ɹnoʎ sɐ ᄐsd ǝɥʇ ɯoɹɟ xoq ɹǝʍod ǝʌıʇɔǝɟǝp ǝɥʇ ǝsn˙ǝɟɐs ɯǝɥʇ ǝʞɐɯ oʇ ɹǝʌo ʞuıɹɥsʇɐǝɥ ǝɯos ʇnd puɐ dn ʞɔnʇs ʇɐɥʇ sʇıq ƃuol ǝɥʇ oʇ pɹǝplos ʇsnɾ ı puǝ ǝɥʇ uı ʇnq ǝɔɹoɟ lɐɯıuıɯ ɥʇıʍ ǝʌoɯǝɹ oʇ pǝʇdɯǝʇʇɐ ı ɥɔıɥʍ ǝsɐq ɹıǝɥʇ ʇɐ ɔıʇsɐld ɟo ǝɔǝıd ɐ sɐʍ ǝɹǝɥʇ ʞuıɥʇ ı `ᄐsd ǝɥʇ ɟo pɹɐoqɹǝɥʇoɯ ǝɥʇ ɯoɹɟ dn ʞɔıʇs ʇɐɥʇ lɐʇǝɯ ɟo sǝɔǝıd ᄅ oʇ ʇɔǝuuoɔ ʎǝɥʇ ʎlddns ɹǝʍod ᄐsd ǝɥʇ uo xoq ɔıʇsɐld ʞɔɐlq ɐ uı pǝsnoɥ ǝɹɐ suoıʇɔǝuuoɔ ǝsǝɥʇ ɥʇoq(pɹɐoq ǝɥʇ ɟo ǝpıs ɹǝɥʇo ǝɥʇ uo ǝɹɐ sɹǝqɯnu ǝɥʇ ɹo)sɹǝqɯnu ʇnoɥʇıʍ suoıʇɔǝuuoɔ ǝɹoɯ ᄅ oslɐ ǝɹɐ ǝɹǝɥʇ ˙ǝpınƃ ɹnoʎ sɐ ᄐsd ǝɥʇ ɯoɹɟ xoq ɹǝʍod ǝʌıʇɔǝɟǝp ǝɥʇ ǝsn˙suoıʇɔǝuuoɔ ʎɹɐsɐssǝu ǝɥʇ pǝpıʌoɹd sǝɹıʍ puɐ ƃnld ǝʇıɥʍ ǝɔıu ǝɥʇ ʇnq ǝɹǝɥʇ ɹǝpun sɹǝqɯnu ʎlqɐqoɹd sǝɹǝɥʇ ƃuıplǝıɥs lɐʇǝɯ ǝɥʇ ɟo lɐʌoɯǝɹ ǝɥʇ puɐ pɹɐoqɹǝɥʇoɯ ǝɥʇ oʇ ʇɐǝɥ ƃuıʎlddɐ ɟo ǝlqnoɹʇ ǝɥʇ ǝɯ pǝʌɐs sıɥʇ sǝɹıʍ ǝɥʇ oʇ pɹǝplos puɐ ㄣdǝʇs pɹɐoqɹǝɥʇoɯ ǝɥʇ oʇ pǝɥɔɐʇʇɐ ƃnld ǝɥʇ ʇɟǝl ı ᄐdǝʇs ƃnld ǝʇıɥʍ ɐ ʎq pɹɐoqɹǝɥʇoɯ ǝɥʇ oʇ ʇɔǝuuoɔ ǝsǝɥʇ ㄣ oʇ ⇂ ɹoʇɔǝuuoɔ ǝʇıɥʍ ǝɥʇ oʇ ʇxǝu ǝɹǝɥʇ ǝɹɐ sɹǝqɯnu uıd ʎlddns ɹǝʍod uoıʇɐʇsʎɐld ǝɥʇ
`ᄅ dǝʇs uoıʇɐɹnƃıɟuoɔ ǝɥʇ uo uoıʇɐıɹɐʌ ɟo ɥʇlɐǝʍ ɐ sǝɹǝɥʇ ǝɹns ɯı ʎlddns ɹǝʍod ɔd ǝɥʇ uo sɹǝqɯnu uıd ǝɥʇ ɹoɟ sɐ`ǝpoɔ ɹnoloɔ ʇuǝɹǝɟɟıp ɐ ǝʌɐɥ ʎɐɯ sɹǝɹnʇɔɐɟnuɐɯ ʇuǝɹǝɟɟıp sɐ ʎlddns ɹǝʍod ɹnoʎ ɟo ǝpıs ǝɥʇ uo lǝqɐl ǝɥʇ ʞɔǝɥɔ ǝsɐǝld`ǝɯɐs ǝɥʇ ʎlʇɔɐxǝ ʎlǝʌıʇɔǝɟɟǝ ɯǝɥʇ ƃuıʞɐɯ ʎlddns ɹǝʍod ǝɥʇ ǝpısuı pǝʇɔǝuuoɔ ǝɹɐ sǝɹıʍ ǝɥʇ ʇɐɥʇ suɐǝɯ sıɥʇ ɹnoloɔ ǝɯɐs ǝɥʇ ǝɹɐ ƃnld ǝɥʇ oʇ oƃ ʇɐɥʇ sǝɹıʍ ǝɥʇ ɟo ʎuɐɯ ʇɐɥʇ ǝɔıʇou ʎɐɯ noʎ ʎlddns ɹǝʍod ɔd ɐ uo
Dc 12v 2.50 A
hope that can help ^^
