3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
photo cube - frameless, cheap and easy!
I made this as a birthday card for my sister, but it's also a great cheap way to display photos without having to buy a frame. It would also make a lovely personalised bauble or gift box.
Step 1What you need
What you need
The first thing you need is six photographs to make your cube. They will end up cropped square in the middle, so to make sure I got the crop I wanted I used the attached mask in photoshop to make all my images fit the same square.
You will also need a knife, cutting board, double-sided tape (glue if you prefer), metal safety ruler (don't risk fingers!) and something to score with. I used a parchment tool, but an empty ballpoint pen or something similar would probably do. This is to make sure you get a good, clean fold in your prints.
29 comments
Jun 16, 2010. 5:24 PMguyzo35 says:
Such a simple, fantastic idea.
Jan 27, 2009. 5:08 PMByr0n_x says:
Very nice, I make one for my wife...
Nov 28, 2009. 4:48 AMFUZ3TTE says:
Memories are almost a woman's best friend
I bet she appreciated it a lot
Dec 24, 2008. 2:35 PMflyhull says:
If you are starting with digital photos you can go to http://easyphotocube.com and make a one-piece pattern to print with your photos already on it. Then all you have to do it cut it out, fold it and assemble it. You can add captions to each side too. It makes the assembly process easier.
Jun 21, 2008. 7:11 PMchicaandjo says:
If you want to take this idea one step further, see our step-by-step instructions on how to make a folding magic photo cube.
May 24, 2008. 9:21 AMbaconrobots says:
I've found that a simple butter knife (using the dull back edge) is great for scoring too.
Mar 24, 2008. 10:25 PMrusticgal says:
Forgot to add, VERY NICE would make good presents
Mar 24, 2008. 10:23 PMrusticgal says:
could you laminate the photos first to keep them clean? or wouldn't it work!
Mar 12, 2008. 8:53 PMultrauber says:
nice job! +1
Dec 16, 2007. 6:05 PMDoctor What says:
Where did you get that cutting mat, and how much??
Feb 23, 2008. 6:49 AMti112 says:
You can get cheap ones from a £1/ 99p shop or $1/99c store (damn yanks). they are not as high quality but i got one and it's quite good
Feb 23, 2008. 7:10 PMDoctor What says:
I got a pretty awesome one for Christmas from my favorite aunt. It's by fiskars, and came with a rotary cutter.
Feb 8, 2008. 2:15 AMhierarchy says:
this is really great! a job well done :) i will definitely try it out thanks!
Dec 27, 2007. 6:27 AMAlicehandmade says:
clever idea!I will make one.Thanks.
Nov 28, 2006. 10:09 AMhethlee says:
i've done this idea WITH a rubix cube... Cut out picturs into 9 little squares and put them on each face of the rubix cube... it turns out neat and it's a puzzle!
Dec 17, 2007. 7:19 PMJaiden says:
neat idea... i think i'll try that
Dec 13, 2007. 7:20 PMSyNiKaLL says:
how do you prepare the photo's to be in a 6x4 print and get it small like that? i've never developed picutres before =/
Oct 25, 2007. 7:28 PMmich1lai says:
I've made one of these boxes in art class -- except with minor differences in the actual construction of the box. instead of cutting out each side individually and taping it back together, we used an exactoknife to cut out one template; then we hot-glued the side flaps together. the instructions for this project are particularly nice and the pictures were very clear. highly recommended.
Jun 9, 2007. 5:20 PMumberto43215 says:
I used a building block for mine which was roughly 4" cube, printed out the photos at a local target store and made a mini version of the original.
Aug 7, 2006. 9:05 AMTheCheese9921 says:
or you could hide stuff in it to prevent theves from stealing stuff (they dont usually go for pictures... i think)
Feb 18, 2007. 1:47 AMPunkguyta says:
Trust me, some people have weird fetishes.
Feb 18, 2007. 1:46 AMPunkguyta says:
A simple yet clean looking cube, I like it.
Feb 9, 2007. 6:41 AMOttawone says:
Wrapping the photos around a wooden cube would also allow you to make little cube puzzles if you cut the original photos into four or six pieces each. I had this sort of puzzle when I was a kid but haven't seen any when looking for my toys for my daughter. Too old fashhioned to be retro, maybe?
Feb 8, 2007. 10:43 AMmrmath says:
If the tape being the same size as the paper flap, I would lay the tape down before cutting the corners off of the flap. That way, when you cut the corners off, the tape is cut exactly to length. Otherwise, very nice!
Feb 8, 2007. 6:51 AMmeatchris says:
Double sided sticky tape will eventually turn yellow and come unstuck. Use glue. Yep, it's a little harder to work with, but lasts much longer.
Oct 23, 2006. 10:57 PMhellion7 says:
i made one right away and love it at just heavyweight paper strength. thanks!
Aug 10, 2006. 7:54 AMradioeyes says:
Something so cheap as a wood cube or rubik's cube would give it strength. I'd be too worried about the above getting smashed or something.
Aug 7, 2006. 10:22 PMimpulse94 says:
Very nice detailed explanation.
Aug 6, 2006. 10:20 PMaustin says:
its make it seem higher quality if you made it around a wooden cube or something to give it some weight .
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Apfrod Works
