3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
pic 12f675 mini protoboard
Since I have a lot of ideas about different usages of microcontrollers it always happens I have to build basic microcontroller setup (microcontroller with oscilator).
Finaly I decided to make a small (or should I say mini) protoboard for PIC 12f675 (which I wanted to use for a small project). You can see the result on the picture.
Step 1The solder side of the PCB
is here.
29 comments
Jan 17, 2012. 7:08 AMajinkyadixit says:
actually what is this ??? pic programmer device or pic interfacing device???
May 30, 2011. 11:59 AMfeldhaus says:
As far as I can see, the main benefit of this board is the integration of the chip with a programming header which, depending on your programmer, could be beneficial. Certainly this would potentially make a nice PICkit-compatible PIC12F675 "package".
For the vast majority of prototyping applications featuring these devices the PIC12F675's factory-calibrated internal oscillator (INTOSC, see section 9.2.5 of datasheet DS41190C) is adequate and frees up an additional 2 I/Os. If you do use an external crystal you should aim to keep its load capacitors very close to the crystal package pins, to limit inductance, and the crystal itself close to the XTAL pins of the device.
Decoupling and PSU reservoir capacitors are a wise addition (certainly at the production stage of development) but hardly critical for breadboarding given the parasitic capacitance and the (likely) quality of bench power supply.
Your PCB layout is neat and tidy, although the spacing from the track to pin 5 of the PIC is unnecessarily close.
Feb 7, 2011. 1:08 PMmarxmarv says:
So try the 12F609/615/617 chips. Trimmed onboard oscillator, no crystal required. :)
Mar 26, 2010. 1:35 PMlj123456 says:
i just wanted to no what components wher used in this project
Feb 6, 2011. 3:06 PMGrazfather says:
Probably a 10uf cap, a .1uf cap, an 8MHz crystal, some jumpers, and a programming header
Aug 21, 2009. 5:43 AMthe_lark says:
Will that also work with a 12f629? I'm new to PIC chips, so I apologise if the question sounds a bit stupid...thanks in advance & well done by the way
Dec 4, 2009. 6:28 AMJodex says:
Stopped doing electronics??!!? Why you did so? =( =0
Dec 4, 2009. 12:15 PMJodex says:
Great! : D Definately make an instructable about that radioactivity detector!!
Aug 21, 2009. 5:47 AMthe_lark says:
Oh and what kind of ceramic caps should I use? Like, 104, 331,103?Thanks!
Aug 28, 2009. 6:11 AMthe_lark says:
ok thanks!
Mar 22, 2009. 4:02 PMHIDvance says:
WOW, some guys are good with PICS!!!...anyhow, HI everyone. I'm new to that PIC stuff and need a hand with instructions. I'm using a 12F675. For instance, I want to read the exact voltage going through pin 7 or 8. That voltage will change with the different lamps I use it with and I need to set an automatic timer with which the moment of shutting the lamp will differ from one lamp to another. Is it possible to read that exact voltage or not? IF it is possible, what would be the instructions for it? Then, do they have to be converted with the ADC? If not possible, how can the PIC know about the value of the voltage goint through the pins? Thanks for your help, Rick
Sep 25, 2006. 12:25 PMian says:
Really nice little DEV-board. I like these 8 pin PICs. Microchip is the only one to make them because of a patent (method for fewer pins than bits, or something). One of the 12F6xx (16F683) has an internal osc of 8 mhz. It is also typical to place a 0.1uf capacitor between the Vcc and Vss (+/-) for decoupling.
Sep 26, 2006. 2:32 AMwestfw says:
Patent challenges aside, microchip is NOT the only vendor to offer 8-pin microcontrollers. Atmel has a bunch (attiny11, tiny12, tiny13, tiny15, and even motorola (oops. "Freescale") has jumped into the act with some of their 68xxx908QTx chips. At 10 pins to 14 pins, you can add 8051 variants from philips (oops. "NXP") and Silicon labs and the TI MSP430s.
Sep 26, 2006. 5:59 AMian says:
Thanks for the correction. I've been working with the MSP430s - I didn't know there was an 8 pin version. I'm going to check it out. Thanks!
Mar 17, 2009. 2:19 AMklee27x says:
Their patent is for the 6-pin PIC's. That's the 10F series. They come in a SOT-23 package a few millimeters across.
Nov 21, 2006. 7:49 PMsysadmn says:
Check out the AVR (atmel) stuff also - internal oscillator, in system programming, nice instruction set.
Mar 17, 2009. 2:35 AMklee27x says:
Yes, AVRs have caught up to PICs regarding built-in peripherals, ICSP, self-programming capability, and super low current sleep mode. PICs had most of that stuff before AVRs did. Microchip was one of the first to start including peripherals like ADC and UART and whatnot on their devices, back when that was just a novelty. On the other side of the coin, PICs have caught up to AVR with an expanded instruction set designed to be C-friendly with the 18F series. The main difference now is that PIC still has the lower end 10/12/16F series chips which Atmel doesn't provide much competition against. Atmel seems to drop production and support of their older models much quicker than Microchip.
Sep 26, 2006. 6:00 AMian says:
Yikes. I read comments about as well as I read datasheets...
Nov 7, 2008. 6:22 PMrobertaugust says:
I will pay bucks for someone to reprogram my 12f675 please contact robertschuttenhelm@yahoo.com
Oct 25, 2007. 9:15 AMTom2000 says:
Nice little board, b0j3. But if you like the 12F675, you're gonna *love* the 12F683! :)
Sep 25, 2006. 10:24 PMcheesy says:
What's the point of putting the microcontroller on a board, then just using in a breadboard? Why not just put the microcontroller (and like 3 other components) directly in the breadboard?
Aug 18, 2007. 9:04 AMfunlw65 says:
Maybe more room for other components on a breadboard. when you have a little one?
Sep 25, 2006. 3:52 PMfiggalicous says:
For those with below-par soldering & programming experience, I agree that these 8-pin DIP package microcontrollers are very inviting. There is another brand called the PIC-AXE, but I heard they're based out of the UK, that's probably how they can avoid patent violation.
Sep 25, 2006. 5:21 PMBeanwaur says:
the pic-axe chips are just microchip pic chips with a preprogrammed bootloader/interpreter
Sep 26, 2006. 1:21 AMian says:
yup. They are more costly and harder to use when you want to count cycles (time based stuff). There are basic compilers that compile directly to PIC ASM code, if you want to use basic I recomend one of these. I used mikrobasic to get familiar with PIC architecture. The demo compiler will output .hex files of up to 2000 words. Later, when you feel brave, you can check out the microchip C18 compiler. There is a free student version, with no limits.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:b0j3
