3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
pneumatic cannon
pneumatic cannon
This is a 3/4 inch pneumatic cannon that is very simple and cheap to make.
THE BEST AMMO FOR THIS CANNON IS PAPER DARTS. they are even simpler and cheaper to make than the cannon. I cannot take credit for this because i found this from someone else but i will put a link for it.Paper Darts
P.S. yes, i did use a few images a couple times.
Step 1Materials
Materials
  • C:\Documents and Settings\User\My Documents\My Pictures\projects\projects 010.jpg
  • C:\Documents and Settings\User\My Documents\My Pictures\projects\projects 001.jpg
  • C:\Documents and Settings\User\My Documents\My Pictures\projects\projects 008.jpg
2- 90 degree elbows
1- long piece of 2/4 inch PVC piping, buy enough for your standards; longer or less depends on you
1- ball and socket valve 3/4 inch
1- 3/4 inch end cap
1- tire valve replacement from autozone or pepboys etc.
1- can of PVC cement
Tools:
Drill
hacksaw or radial arm saw
sandpaper
tape measure
bike pump WITH PRESSURE GAUGE
pen
DISREGARD THE PIECE THAT IS CONNECTED, THE TWO ELBOWS AND SPLIT PORT, it was for an add on but i messed it up =/
16 comments
Dec 27, 2011. 10:17 PMTylerBerzzz says:
can this thing shoot a golf ball?
Mar 1, 2011. 4:22 PMlil larry says:
What size elbow do I need? Becuase it doesn't say what size on the ible.
Jan 5, 2010. 4:42 PMmdl99 says:
making this!
Oct 3, 2009. 6:36 PMstruckbyanarrow says:
it cost me 6 dollars to make a cannon with a 3/4 inch barrel and a 1 inch chamber
Apr 9, 2008. 12:26 PMtony48 says:
What waas that add on that you were going to make?
Aug 3, 2007. 12:40 PMtony48 says:
how much do ball valves cost?
Nov 14, 2009. 3:06 PMColonel88 says:
But isn't it better to use a sprinkler valve since that doesnt screw up ur aim as much. FOr example the ball valve takes a lot of force to open, so you JERK it and ur aim is off. Then you are screwd. But on sprinkler valve u just flip a switch and you can even make a button trigger, ti make it more of a gun. Im working on a sniper/ AUG design
Jun 25, 2007. 4:36 PMccrook says:
Why both gluing the tire valve in? If the hole you drill is just small enough to force the valve's lip through from the inside out, the inside pressure will keep it in place. I believe I used a 3/8ths bit for my old pneumatic potato gun.
Jun 25, 2007. 6:12 PMccrook says:
I would use caulk or some other semi-flexible adhesive around the rubber tire valve if you need to re-glue it. Super glue is extremely brittle.
Jun 25, 2007. 4:37 PMccrook says:
Oh, and a little silicone lubricant makes it easier to push through, too.
Jun 25, 2007. 6:00 PMfinfan7 says:
I made something very much like this a couple years ago. I used a 1 inch wide tube for the barrel i think about 4 ft long. The standard u turn and valve and then a big air canister i think 4 in wid by 1.5 ft long. i don't have it here so im not sure how accurate that is. fired pebbles accross the park though.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:pbpenguin5
