Pneumatic Skewer Gun / Rifle. Not Pvc,
Published
Introduction: Pneumatic Skewer Gun / Rifle. Not Pvc,
A pneumatic skewer rifle made from left over plumbing parts from the shed.
Fires reasonably well, only tested at around 100 P.S.I fairly self explanatory construction,all measurments were purely guess work, and although ive included a few images for scale later minor adjustments were made, please leave any questions as comments.
parts;
length of 15mm copper pipe (around 6ft), 4x compression fitting corner pieces, 3x isolating valves, 1 of which is a tap type the other 2 screw driver operated (although all tap would be preferable), 1 solder banded end cap, bolt in car tire valve, ptfe tape, epoxy resin and
6mm (4mm inner diameter) aluminium pipe.
To pump up: open first valve (nearest tire valve) and second leaving final closed, pump up (not tested past 100 P.S.I), close first and second valve, drop skewer down barrel, to fire release third valve, to reload close third valve and open second.
I accept no responsibility for damage done to property or self as a result of making or attempting to use this.
first instructable (well slideshow) so be constructive. sorry about poor photograph quality.I'll add a video when i can, if requested.
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    4 Comments
    Were can I find a piece of aluminium pipe like that. Working on a pneumatic gun to shoot arrows and I cant seem to find a tube that small.
    sorry for the late reply, yeah the cheap 100 for £1 bamboo skewer. E
    tested to 200 P.S.I, no leaks, or explosions although the power increase wasnt particularly worth the extra effort, typically fires 3 skewers about 2cm into a pine door. E
