Introduction: Pneumatic Sniper Rifle
This is a a great begginer project for someone who wants to build a pneumatic potato gun. pricing is reasonable, being around $50- $60. took me only an hour to build. The only thing that i would change is the handle, it shold be bigger to hold more air. I havnt found the range yet because I am not sure how much pressure it will take. I dont want pieces of pvc stuck in myself!
read final page for legal.
ps. sorry about photos, my camera is broken so I have to use a phone.
Step 1: Parts
WARNING: MAKE SURE ALL PARTS ARE PVC PRESSURE FITTINGS
-3 of 25mm 90degree elbow
-25MM TEE
-25MM PIPE
-15mm pipe
-2 of 25MM vavle socket
-25mm h/style/w/o valve solenoid
-20 by15mm reducing co
-tape (optional, added for strength)
-clear tube ( will jam into trigger without leaks
-air trigger
-schrader valve (car tyre valve)
- a bit of brass (u will need to thread this and drill through the middle) see pictures.
-pvc glue
Step 2: Construction
MEASURE! then cut
Glue the parts together, prime if u think necessary
making sure everything is straight becuase pvc glue dries extremely fast!
Dont forget to put in the schrader valve as well.
Now tape up the tubes, i used a roll of electrical tape.
Step 3: A Closer Look
The sprinkler valve was taken apart
-a hole was drilled in the top, on an angle
-the hole was threaded
The piece of brass was cut down
- a hole was drilled through the middle
- one end was tappered using a file
- the other end was threaded using a TAP AND DIE SET
- the brass was then screwed into the valve with plumbers tape to stop leaks.
Step 4: Wait
You may be excited to see if ur toy works. but please wait the full 24 hours for the glue to set.
24
23
22
21
20
19
18
17
16
15
14
13
12
. i think u understand the waiting part
Now u can test out ur toy. slowly pressurize. Im not too sure how much these pipes will hold. I have only tried mine upto 50psi but I am sure it would go further. dont over-do it though. pvc shatters and sends bits flying everywhere.
fire what u like, potato, marshmallows, or um... stell balls. just remember though, this is now considered a weapon and is illegal to own or use. I will not be held responsible for any damage, injury or death. if u make this project, it is your own responsibility.
so what will u do now, why not modify it? change the barrel, chamber, trigger, change it to fire water balloons... the list goes on. see what u can come up with.
