3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
pnuematic pocket football cannon
This instructable is an air cannon that fires nerf pocket footballs at 145psi up to 450 yards. For is simplicity i think this is one of the best high powered air cannons on instuctables. If your wondering why i didn't usea sprinkler valve its because it doesnt release the volume of air a ball valve does and i didn't feel like spending $60 on a 2 inch sprinkler valve. All the pipe i used was pressure rated to 250 psi and up. The valve being the acception it was rated to 165 psi. I am making a pnuematic ram to turn the ball valve very quickly.
Step 1Collect what you need
collect what you need
To start buy the following as seen in the image below.
65 comments
1-40 of 65next »
Sep 22, 2011. 9:16 PMballistic builder says:
I have built one of these a while back, it is awesome
do you mind if I use the concept for an instructable to make a nerf gun the same way? (i will link it to this instructable)
Jul 19, 2010. 2:13 AMdorro says:
what type of tire vale did you use and where did you get it from? also what sealant did you use on the valve to keep it air tight?
Aug 13, 2010. 7:50 PMAudio Alchemy says:
I used a tank valve. It is supposed to go on a portable air tank. Drill a 3/8 hole where you want to and wrap the threads with teflon tape. I got mine at the auto parts store but major DIY home improvement stores should have them in the pneumatic tool section.
Jan 26, 2010. 9:58 AMAudio Alchemy says:
I have built this cannon.  The only thing different is that I used a brass ball valve with a large handle that lets me "throw" the valve open very quickly.  I also have made interchangeable barrels.  For golf balls I used 1.5 inch SDR 21 Sch. 40 PVC.  For foam "mini footballs"  I used 3 inch Sch. 40 PVC.  I also have a 2 inch barrel for the "nerf" pocket football but I have never used it for fear of losing the only one I have.  This cannon is VERY powerful!!!  At only 100 psi I can puncture my METAL wheel barrel with a golf ball  from about 30 or 35 feet.  The only cons (which are very insignificant) is that the darn thing is rather heavy and it takes a while to pressurize up.
Mar 1, 2009. 7:39 PMhackmattr says:
Bell reducers are not pressure rated so I would not use them in building an air cannon.
May 23, 2008. 8:47 AMpolabearboi says:
can you use a bike pump?? if not what should i use? please help
Jan 22, 2009. 10:39 PMThe Porsche Fan says:
a compressor works fine if you have one, bikepumps are pretty slow
Jun 11, 2008. 3:08 PMpolabearboi says:
would it be a bad idea to drill a hole in the air reservoir and stick a pressure gauge in it?? really sweet gun btw. roughly how much for all the materials??
Jan 22, 2009. 10:41 PMThe Porsche Fan says:
it would probably compromise the pressure rating (blow up?) you could make a metal valve extension, but most compressors, or bike pumps already have a gauge on them
Sep 16, 2008. 3:11 PMi wanna do that says:
wow really good cannon, but how much and where did u get such a high pressured rating pvc piping from?
Jan 22, 2009. 10:38 PMThe Porsche Fan says:
you could try home depot
Aug 19, 2008. 5:51 PMballistic builder says:
awsome, works great
Aug 1, 2008. 10:01 AMpolabearboi says:
any other things u recommend firing?
Aug 1, 2008. 9:59 AMpolabearboi says:
hey! i finally got all the materials (and consent form my parents) and just built it last night evry body was thinking like 2 ft. and it wasnt gonna work but we were all amazed at how far it went it is an awesome gun!!
Jul 26, 2008. 10:54 AMwunmanband says:
what powers it?
Jul 29, 2008. 9:47 AMilldoyourdrugs says:
Pnuematic Equals AIR
May 24, 2008. 7:05 AMpolabearboi says:
where should I look to find all these materials????? how much will it all cost? please help
Apr 15, 2008. 2:24 AMchibiwind says:
On step 1 it says 3 inch end cap with tire valve do u have to put the tire valve in it or can you buy it like that...?
Apr 22, 2008. 11:36 AMjoedynamite says:
what kind of compressor or pump do u use to get that pressure!!! cause i am looking for one and i dont know where to go and where to look.
Apr 23, 2008. 8:28 AMDerin says:
u need one rated for 10 bars
May 18, 2008. 11:06 AMpolabearboi says:
did u get 450 yds w/ or w/o the mods?
May 3, 2008. 7:34 AMjoedynamite says:
idk what tat means but i just had my b day and my dad got me all the stuff i need he got me a compressor with a 5 gallon tank at the bottom i guess that will work but i could die because theirs no gage on the compressor or the cannon. so i kindof have to go wit the gut fellin
Jan 22, 2008. 12:53 PMPerfectlySquare says:
Using 3.1415 (four places seems more than enough) as the value of Pi: A 4' L x 3" D cylinder has a volume of 1357.1258, and a 4' L x 2" D has a volume of 603.168, making your ratio 2.25:1, and not 3:1. :) I am going to the Depot today for the parts,so I will let you know how mine turns out. I'm going to build mine from ABS so it can handle much higher pressures safely! I'm already fantasizing about getting it up over 200 psi...
Jan 22, 2008. 7:26 PMPerfectlySquare says:
Ah...well, you didn't say that! :P
Just picked up all my parts and was dry fitting it all, when I tried out the ball valve and it would barely turn. I tried greasing it, but it made things worse, so now I get to make a trip to the Depot tomorrow and get a better ball valve. I also switched to Schedule 40 PVC since I was told by the guy at the plumbing wholesaler that it's the most durable stuff thats readily available.
Got a question for you though...I got a Schrader valve for the chamber, but it's shaped like this. I dont think it will fit right given that the thickness of the wall of the pipe is bigger than the gap between the round knub on the end and the tiny lip that seals it .
Do you have any tips for getting a safe connection to the chamber from this type of valve, or is there another type of Schrader you recommend? I went to Home Depot, the auto parts store, a bike shop, and the tire store. The auto parts store had bits and pieces, but I wasn't sure which I'd need so I tried to find something already put together. The bike guy gave me an old tube with a valve and the tire guy gave me what you see in the picture. I could go either way, I just want to make sure I do it safely.
Thanks in advance for your help!
Mar 19, 2008. 5:41 PMmking2012 says:
You can duct tape a thin PVC pipe as a firing lever. I tried it on a launcher that I built and it made a huge difference.
Jan 24, 2008. 12:16 PMPerfectlySquare says:
Do you ever have a problem with the valve falling inside the chamber if it's pressed on from outside? That was my main concern, but since it's what I got and FREE, it's going to be the valve. I made one goof while welding the pieces together...I moved the parts out of "mockup" positioning due to workspace limitations, and as a result ended up switching the 6" and 18" pieces around. DOH! Welds are permanent! :P I just trimmed the 18" section a few inches so that when I'm finished the two sides (chamber and barrel) will be equal in overall length. I'm sure it tweaks my power a bit having a longer section between the chamber and the barrel, but since there's really nothing I can do, I'll just have to see how it comes out in the end. At least it will have some symmetry, which will look cool. I also ended up going with a 1" ball valve instead of a 2", since none of the 2" valves I found turned fast enough to release the pressure efficiently. I used 2 (2" to 1") adapters with two 1" threaded nipples to connect the valve. I am thinking since it's going to be smaller this will ramp up the pressure a little bit, and hopefully will help compensate from the screwup I made, but we'll see. At least it turns quickly, and without hurting my wrist! I should be fully complete this Sat, so I will try and get some pics/stats up after I get it out in the field. Thanks for the tips, I can't wait to hear what you think!
Mar 8, 2008. 12:08 AMblugyblug says:
Nice gun!! Execpt that chamber is waaay to big. If your chamber is too big it might actually make it less powerful. The chamber should be about 2 times the volume of your barrel
Jan 21, 2008. 2:17 PMry25920 says:
You need to lower the PSI or your going to kill yourself. sch 40 PVC will rupture at 170psi and your pushing your luck.
1-40 of 65next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:frankinator
