3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
pocket abacus
Step 8How to multiply
how to multiply
here's where the abacus comes into it's own.
multiplication vocabulary:
multiplicand : the number to be multiplied
multiplier : the number to be multiplied by
(In multiplication these terms are generally interchangeable)
product: result of the multiplication
Let's take 2 larger numbers:
                                                    5286 x 654
The trick here is to count the digits in the equation, in this example there is 7 digits. This means we'll need 7 columns of beads to compute our answer. Reading right to left that puts us at the red column, this is where we'll start.
Now we take our top row and multiply it by our first multiplicand (5286 x 6). Our first calculation is 5 x 6 which we know is 30, this makes our 7th column (red) at +3 and the 6th column (yellow) left at +0. Continue over and take 2 x 6 which is 12, this makes our 6th row +1 bead and our 5th row +2 beads. Continue this process until the multiplier is exhausted.
Dropping the first digit of the multiplier there are now only 6 digits, this means we will start on 6th column over for the next multiplicand. Repeat the multiplication, adding beads in each column and carrying over the remainders.
When you exhaust the multiplicand the calculation is done.
We can verify this on a calculator and we see that it is correct.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
763
Author:mikeasaurus(michaelsaurus.com)
I'm the Play Editor here at Instructables! I like mixing old ideas with new and reusing things not for their intended purpose; the results are sometimes messy but always fun. I also write the thrift-...
more »
