Pocket Size Hotwire Machine
Published
Introduction: Pocket Size Hotwire Machine
this is my first instructable so i decided to enter it in the pocket size comp
its quite simple to make and mine cost nothing
you can use it for small craft/hobbie work and use it to cut through foam/polistyrene and any other small soft foam
all you need is
a small piece of ply wood
mdf
guitar string
9 screws
2 pins
disposible camera circuit
9v snap
resistor
wire
tools
soldering iron +solder
drill
pliers
screw driver
saw
Step 1: Cut the Wood
this here is just the basic construction of the frame
first cut the ply wood to 2 bits 10 cm long and 1.5 cm wide and 0ne to 5 cm long and 1.5cm wide
then cut the mdf to a 5 cm square you will be needing 2 of these as well
Step 2: Frame
assemble half of the frame but keep a piece off the mdf off
and screw or glue together
Step 3: The Circuit
for this step you will need your soldering iron and solder
your camera circuit and some wire
a pair off pliers also can help
first desolder the batterty contacts and solder the resistor and snap on
then take off the capaciter and solder two other wires
and on the wire butten on the back you will need to put a blob of solder on that
Step 4: Screw on the Next Piece of Mdf
leave the wires hanging out and put the two front wires on the pins 1.5 cm froim th top
twist the guitar string on to the pin really tight
screw on the last piece of mdf
connect a battery and then you are finished
    • Planter Challenge
      Planter Challenge
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    11 Comments
    Looks good - what bit of the camera circuit are you using, which guitar string, and what value resistor? L
    I think he is using the transformer because you need higher voltage than the 9 volt battery provides
    I wouldn't have thought so for steel wire. The current you'd get out of the transformer would be too low and I can't see the circuit handling that much power ? L
    Probably the flash, everyone seems to use it.
    i thought you ment how to hotwire a car by a hotwire machine
    Am I missing something? What exactly does this do? I've got a few guesses, but even if I'm right I'm sure I'm not the only one who would benefit from a a line or two about it's function.
    hi you can use it for small craft/hobbie work and use it to cut through foam/polistyrene and any other small soft foam hope this helps.
    That's what I thought, but you may want to add that in the actual instructable somewhere. Good job by the way.
    After reading that it sounds a little sarcastic, and I really don't mean it to be. I actually do think a note about it's use would be good.
    you use the whole circuit and you use the small guitar string (metal) and its a 250 ohm value resistor
