3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
portable 9V to 5V battery
Step 1Checklist, parts and tools.
checklist, parts and tools.
parts:
- 9V battery (duh)
- 9V battery clip (duh again)
- 5V regulator ( L7805 ) sparkfun $0.85
- a piece of proto board
- 2x 1uF ceramic disk capacitor (this isnt really that exact, use about this value if you do not have it)
- an aluminium heat dispenser (not sure if its really needed, i added it just in case)
- some heatshrink if you mess something up like me (if you do it right, unlike me, you wont need it)
optional:
- a green status led (+150ish ohm resistor)
- a switch
tools:
- soldering iron
- dremel
- needle nosed pliers
- third hand (not really needed, but makes it all alot easyer)
- multi-meter (or osciloscope if ur rich...)
- hot glue gun (or just some glue sticks and a candle, if you broke your gun like i did)
there's also a schematic here.
13 comments
Mar 8, 2012. 6:38 AMnodoubtman says:
i think that doesnt work for a ipod touch 4 G?
thank you!
marC:)
Aug 16, 2011. 4:14 PMtdobbins1 says:
Why do you need the 2 capacitors?
Jul 23, 2011. 12:03 PMseben says:
would you be able to charge your psp 3001 with this.
Jul 23, 2011. 12:12 PMseben says:
weres the switch?
Jul 6, 2011. 11:17 AMRobot Lover says:
I don't think you need a heat sink for the regulator unless you are you using some higher-current voltage to go into it. So it's optional.
May 24, 2010. 2:37 PMAdum24 says:
Will this work with an ipod touch?
Mar 28, 2010. 5:47 AMEric_bard says:
No schematics?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:godofal(godofal)
... what? is this thing turned on??
