Portable Solar Charged USB Charger
23,612
131
15
Published
Introduction: Portable Solar Charged USB Charger
About: Interested in different things i could possibly make.
1- What did you make?
The project is a Solar Charged USB charger, There is abundant sunlight emitted at this moment and we could use this light to charge several things such as batteries, cellphones and such more. I thought that this will be useful especially when we go into a long trip or such we wont loose power in our modern gadgets like cellphone that can be charged by a USB port or even powering up a USB fan.
This works by placing the project into the sun and let it charge for several hours to make it fully charged. Making this a portable USB power supply i used a 3 AA battery to power up the DC-DC boost converter. The boost converter wont put out a regular supply so I used a voltage regulator to make it a constant DC 5V output. The reason for a boost converter is to be able to use a small voltage battery like 1.2v AA NI-MH in series to not exceed 5 volts. Exceeding to 5v of battery will be hard for the solar panel to charge it. Casing is not a very big one and all components is fit inside so this is the one i used.
How does it work?
- Solar power is abundant at day time and we want to store as much as possible in our battery pack. when it is turned off it is constantly charging until it gets full but then if you will use it regularly then i recommend you to place a DC plug to charge your battery from the wall.
The reason for making this project is to have a portable charger and to charge it anywhere in the world. If you ran out of battery and you still have no outlet then we will use the Solar panel to charge our battery. But the disadvantage for this solar charger is that it takes couple of hours to charge.
this this solar panel gives out 200mA of current in full sunlight to charge a 2700 mAH of battery pack. to solve for the time it will take around 13.5 hours to charge it fully. to solve use the formula
Charge capacity            2700mAH
-----------------------   =  --------------------  = 13.5 hours
Current charger             200mA
Just cancel the mA and divide the numbers to have the answer.
2- How did I make it?
I got the idea from an article about sun power and charging a DC input with a Voltage regulator. This project was supported financially by my friend. My plan is to have a smaller casing and use 2 AA battery but the materials that is available did not permit my plans so i went with the flow finding alternative ways to complete this project, but still with my knowledge of Electronics.
3- Where did I make it?
This project was made in the house and was demonstrated in school, this project took me 1 day of finding the materials and 1 day to assemble and to trouble shoot it is a total of 2 days only. This project was able to help me charge my gadgets with the power of sunlight and may there be a time that we loose battery here is the project we need.
4- What did I learn from this project?
The biggest challenge is to find the things with creative knowledge. While building this project I have learned that nothing is easy if you don't strive hard for it. As my teacher said "Work Hard, Pray hard."
I am proud that i was able to make another successful project with what i have. If i had to make this project again I would upgrade this project by placing battery level indicator, charge limit and sunlight detector and so on. If i could even find parts that would be smaller it would be more portable.
Step 1: Materials
The things needed are the FF
Main
 - 3 rechargeable battery (NiMH)
 - 7805 Voltage regulator
 - PCB (optional)
 - Resistors (75k and 50k ohm)
 - USB female PLUG
 - 3.4v-8V+ DC-DC converter
 - Battery holder (4 cell)
 - Switch
 - Heat sink (optional)
 - SOLAR PANEL (1w or higher  Nomial voltage: 5v)
 - Wire
 - Blocking Diode
Tools
 - Soldering Iron
 - Portable Drill
 - Multitester
 - Screwdriver
 - Wire stripper
 - Safety Gear
 - Permanent Marker (PCB Development)
Chemical
 -Ferric Chloride (etching solution)
Step 2: Casing
making the casing would need some measurements and the fitting of the needed parts
USB PORT
1. draw the USB female plug in the place you want
2. Make sure everything fits inside with your design especially the battery holder
3. after making the sketch of the USB female plug drill the necessary hole for it.
4. make sure it fits, if not make adjustments.
Switch
1. draw the marks that needs to be drilled
2. make the hole to the needed mark.
Note: this is the very last step
Solar Panel
1. Drill the necessary hole for the wire to go into the cover
Note: if you got the parts like mine do this step if battery case is fixed in.
Step 3: PCB Fabrication
Make a Mini HUB for your DC-DC converter
just 3 lines for INPUT, GROUND and OUTPUT
Make another PCB with your desired design for the USB female plug
Follow the design like the one in the picture.
you can use a presensitized board or just use a marker to cover the marks in in the etching process (removing excess Copper)
Step 4: Wiring
Follow the schematics seen in the image
Battery will be charged even though it is turned off.
 the battery could be fully charged in approximately 13.5 hours via solar panel.
Connect the positive side of the battery to the input of the DC-DC converter
connect the negative (black) to the ground of the DC-DC Converter
connect the output of the DC-DC converter to the PCB with the 7805. the output will be connected to the input of the 7805 Voltage regulator.
the ground will be connected to the ground of the 7805.
the output of the 7805 will be connected to the USB pin please refer to the Schematic diagram.
the solar panel and the battery will be connected together so that the solar panel could charge the battery.
there is a switch so that the DC-DC converter wont eat the power even without use.
R1 and R3 is the 75k resistor and the other 2 is the 50k resistor
Step 5: Switch
Just cut the connection from the power to the DC-DC Converter
Step 6: Test
Switch it on and try to plug your device.
You could also plug USB electric fan and so on as long as it is USB powered.
Making this as an Emergency light could be possible as long as you have a USB Lamp or LED.
after plugging a device you should hear a noise coming from your dc-dc converter.
If you will be making this project i recommend you to place a Voltage level meter so that you know when to charge it and not to use it.
Making this portable and to just make a charging station for this portable charger it would be faster especially if you use a big Solar panel providing high Current.
Don't forget to turn the charger OFF when not in use or you just wasted your charged batteries.
What makes this project expensive is the solar panel and the Battery pack.
Thank you for reading this Instructable.
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
    15 Comments
    Nice instructable, I love step-up circuits too. But I see that the converter you're using has a 34063 IC. Because I've recently been playing with these chips, I believe you should be able to get a 5v output from the converter without the need for the 5v regulator, saving energy. Maybe that potentiometer? I wouldn't know about that circuit because I build mine part by part. Anyways, good instructable.
    I tried to find an Linear boost converter with the output of 5volts but the problem is I cant find any in my location
    Hi there! How do you ground the excess charges produced by the solar panel after the battery is at full charge, so that the battery does not overcharge?
    I really like your step by step instructions! However, I am doing a project at school and I was wondering how this project could be made better. I was thinking that maybe there would be a way to allow the solar charge to be held longer or if it could be an overall outlet, not just a phone charger. But I really enjoyed this DIY.
    nice instructable.. i want to make this.. may i know about all componet do u used it?
    and where can i buy it? can u tell me pls?
    i'm sorry if my english is not good. :D
    Wait did you use a voltage regulator?
    O! I do see it listed in the items. I am a noob at this...
    but I have heard that a DC-to-DC converter is a bit more efficient than a voltage regulator. The claim was that regulators take the input voltage like 6v and will burn heat to drop the voltage to 5v, which cause wasted energy.
    And a DC/DC converter will actually convert the extra volt into more amps. But still only efficient so much.
    From my theories... I am now a believer. Regulators are in cars to run different electronics. The alternator is giving electric power to everything, so who cares if there are several simple design regulators because there is plenty of power.
    Here is a link that I got info about the regulator vs the DC/DC converter: http://www.trevorshp.com/creations/solarcharger.htm
    3 Things You Should Know When Buying A Power Bank
    For More Information : http://bestnewpowerbank.com/
    When it comes to devices that charge your gadgets on the go, there are tons of external battery options out there, tons of portable solar panels and transportable solar panels out there, and finally, many crossover devices that are portable solar panels with built in external batteries.Click here
    i do not think you dc-dc converter. you may choose your solar cell or manipulate cause converters performance is not so good. (90percent maybe).
    nica!! I was working on the same project but to be built-in on a backpack or suitcase
    That is nice. :D
    Nice!!!!! Great Idea Sou!
    Some few recomendations to attract viewers:
    1st.) Better lighting and better camera
    2nd.) Dont speak in "Tagalog/ Filipino" :)))
    3rd.) Use Fritzing instead of eagle PCB/ schem creator.
    Ganda na, lalo na yung idea, gandahan mo lang pictures :)))
    I am using a good camera what lacks is good lighting and UR LIGHTING STUDIO haha..
    ?? i am using english.....
    I am using fritzing print screen lang un
