Portable Charger
Published
Introduction: Portable Charger
Most of the mobile phones these days can be charged from a USB port with an output of 5 v DC. now u can charge your mobile phones anytime anywhere using this simple portable usb charger.
Step 1: Components Needed
The components we will use are:
One - LM7805
Two - 1μf Capacitor
One - 5 Ω 3 Watt Resistor
Step 2: The Circuit Diagram
The circuit is very simple and can be soldered very quickly on a small general purpose PCB. The components from left to right are, 7805 , 5.4 ohm resistor and two 1uf capacitors.
I have sketched the layout along with the 7805's pin configuration. It is a fairly simple and straight forward circuit. The positive input is connected to both the pin one of the 7805 and the positive of the first capacitor . The pin three is connected to the positive of the capacitor and one end of the resistor, this forms the positive 5 v output. This completes our positive side. For the negative we connect all the negatives together - the negative in, negative out, negative of the first capacitor, negative of the second capacitor and pin 2 of the 7805.
Step 3:
The output can be taken as a wired output or a USB port can be directly mounted on to the PCB. Here you see the completed board. I have drilled two holes to secure the port later. The red and the black wires are the input wires.
Step 4:
    • Make it Move Contest
    • Microcontroller Contest
    • Woodworking Contest
      Woodworking Contest
    8 Comments
    good work, but the biggest question is.......
    From where you will get input voltage, since you need DC voltage little more than 5 volt say 8-12 volt.
    If this circuit were a complete then it would be nice one.
    from a 9v dc battery!
    u may use a battery cap to make connection with battery easier!
    What's the 5.4Ohm resistor for? There is no need for that.
    By varying the resistance of the resistor between 5 and 15 ohms the output current can be reduced or increased as per requirement. While doing this ensure that the resistor you use is rated at 3 watts or above and that the 7805 has a very good heat sink and that it doesn't overheat. A small amount of heat however is quite normal.
    Ah yes, ... well, no.
    If you design something with an USB connector, it should behave like a powered USB device. With a USB device, the voltage is stable. With your design, the voltage drops when the current consumption increases. That's just the opposite A 7805 is used for.
    If you need a current limiting resistor in your charger put it there. Anyway, for anything more sophisticated than a NiCd, you should use a better charger design.
    Your remarks about the heat sink should go into the instructable together with the according thermal design formulas. And you should state the min/max supply voltages.
    280x158px is way too small to see whats going on, a better size would be like the components pic(1600x900px) in step 1, other than that cool idea.
