Potato, Bacon and Red Onion Crispy Pizza
5,813
73
11
Posted
Introduction: Potato, Bacon and Red Onion Crispy Pizza
Pizza Contest
Finalist in the
Pizza Contest
I love this pizza. It's a little bit unusual but then most of the best things in life are. I like that is doesn't have the classic tomato base but it still has lots of great flavour. You could by all means make a deep pan version of this pizza but I feel the crispiness of a thin base is what's needed here. Also, if you like your food extra stinky chuck on some minced raw garlic before cooking. This is something I often do.
These quantities give you enough for two 25cm thin based pizzas. I started with raw potatoes for this one but you could just as easily use up some left over roast potatoes. I used my trusty cast iron skillet as the cooking pan for the pizza. It is the perfect size for a single serve pizza.
Don't forget that if you like this recipe you can get lots more tasty food ideas on my blog. http://eating-properly.blogspot.co.uk/
Step 1: Get It All Together
The Dough Ingredients
1 kg strong white bread flour
1 tsp salt
1 tbsp sugar
14g fast action dried yeast
4 tbsp olive oil
approx 600-700ml warm water
Ingredients for Everything Else
1/4 of the basic pizza dough from above (approx 300-400g)
1 small potato peeled and very finely sliced (a couple of millimeters is best)
50g finely diced smoked prosciutto or bacon
1 small red onion finely sliced
couple of tsps pesto (optional)
1 sprig of fresh rosemary, chopped
1 ball of mozzarella
Salt and pepper to taste.
Step 2: Make the Dough
  1. Put all the dry dough ingredients into a large bowl, make a well in the centre and pour in the oil, Using a butter knife or your hands start to bring the ingredients together. Gradually add the water, little by little, until you have a rough dough. You may not use all the water or you may need to add a little more. Knead the dough in between each addition.
  2. Once you have a rough dough turn it out onto a lightly floured surface and knead for around 10 minutes or until you have a smooth springy dough.
  3. Place dough in a bowl, cover with lightly oiled cling film then leave in a warm place to rise for about and hour or so.
  4. In the mean time combine all the topping ingredients in a large bowl until evenly mixed. Cover and set to one side until needed.
  5. Once the dough has risen uncover it, knock it back and divide into your required number of portions. I split mine into four balls. One ball will make one 25cm deep pan pizza or two 25cm thin crust pizzas. Put any remaining dough in the firdge if using in the next couple of days or you can freeze it up in freezer bags.
Step 3: Prepare Your Toppings
  1. Place your sliced potatoes in a bowl and pour over some freshly boiled water from the kettle. The aim is to scald them slightly so that they are not completely raw before going on the pizza. Leave for around 10-15 minutes then carefully drain off the water and remove the excess water from the potatoes with absorbent kitchen paper. Set to one side until ready
  2. Place a small frying pan over a gentle heat and crisp up your bacon/prosciutto pieces. Don't go too far as they will continue to cook in the oven later.
Step 4: Put It All Together
  1. Preheat your oven so that it is pretty much as hot as it will go. I generally go for 220C. Put your baking sheet/stone/skillet in the oven and leave to heat up.
  2. Once the oven has reached full heat, roll out your dough to the size of your cooking pan.
  3. Place the dough in your pan taking care not to touch it as the pan will be super hot.
  4. Put half the potatoes on each base in a thin layer. You want a single layer of potato across the whole base. Scatter over the bacon, rosemary and onion slices then dollop on a little pesto if you're using it. Finally add the mozzarella and a little salt and pepper.
  5. Bake in the oven for around 13 minutes or until the pizza is a nice golden brown.
  • Gluten Free Challenge
  • Sew Warm Contest 2018
11 Comments
Sounds wonderful will have to try it very very soon. Thank you!
Good combination of toppings! I thought I was the only American who likes potato on pizza. I usually do it real simple with olive oil, herbs, garlic, potato and parmesan but this looks delicious. I'll try it soon.
Cheers climber_geek. I think this is a fairly classic combination of flavours, it definitely works anyways. Glad you like it. :D
Thanks donedirtcheap and mistyp. Glad you like my work. :D
I can imagine how much work it took to make your instructable look so good. Beautiful work and good luck.
Congrats on becoming a finalist! Good luck!
This sounds really good. Thanks for posting it.
Oooh! Very unique and tasty sounding! You always have such neat recipes :)
thanks Penolopy, glad you like it. You can't really go wrong with potato, bacon, onion and cheese can you? :D
