loading
Step 3: Modifying the Torch Head
This bit varies from torch to torch, and has given me the most grief! The inexpensive torches I've bought are generally formed from a rubber 'overcoat' with (actually, fairly brittle) plastic inserts giving the structure.
The head has, as expected, most of the important components within - there's an exploded view below.
My approach was to dispose of the bulb, and use the soldering iron to melt down the reflector to accommodate the circuit board. I also trimmed the square edges off the board with the wire cutters to help it fit a little better.
The ideal would be for the LED module to fit into the reflector assembly so that the tops of the LEDs lie flush with the front of the reflector - this would mean it can be refitted into the lens assembly without any further modification.
In the event, though, I had to opt for hacking at the reflector to retain the thread for the bottom cap, and use blu-tak to rest the module within it. I found the easiest way to 'cut' the reflector to size was to use the hot soldering iron bit to melt it, trimming off the excess with a craft knife. Ensure you have good ventilation if you choose to do it this way, since it can emit some nasty fumes.
Now's the time to solder the loose wire to the metal negative circular plate. If the reflector assembly is still intact, this will require another hole to be made in it, to allow the negative cable to reach the plate without going near the positive terminal.
Next trim the 'positive leg' so that it comfortably rests on the springy contact of the positive terminal in the screw-on cap. To facilitate this, I bent the terminal up a little so that it could get as good an electrical contact as possible.
The ebay link is no longer valid, does anyone know a place online to get the leds and resistors?
Nice instructuble, I'd like to make something similar myself. But I think it's better to wire some LEDs in series, instead of having all of them in parallel and needing resistors, which is a waste of energy. But in your case you would need more than 4.5V
About This Instructable
5,749views
13favorites
License:
Bio: I'm a bloke who lives in Luton - I love music and radio and comedy, and pretty much any combination of the three. I've ... More »
More by cacophonyx:£1 Poundland Übertorch (3 D-cell 25 LED torch conversion)
Add instructable to:
