3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
private amp from a old personal cassette player
hi folks today im going to help all our guitar playing friends improve their relationships with neighbours and or family.
no im not going to personally give them each 50 bucks to leave you alone what im going to do is supply you with the knowhow to make a small guitar amp that will only annoy you {well it may annoy you if you play bad like me}.
best of all it only takes about 10 minutes to do
Step 1What yer gonna need
what yer gonna need
ok to do this your going to need
1. old personal casstte player that you dont mind destroying
2. guitar cord that you dont mind cutting an end off{ we all have one that only works when you bend it}
3. a fine soldering iron and rosincore solder{you can sharpen the point of a cheap pencil iron}
4. a set of head phones
5. an electric guitar or acoustic with a pickup installed
55 comments
1-40 of 55next »
Apr 22, 2012. 2:32 PMTheBookworm says:
I would reccommend adding a resistor between the guitar and tape player, as the guitar input is stronger than what the tape player is designed for. Also, Disconect the motors from the circuit, and leave the conecctions without anything connected, as this will conserve battery power, and stop the clicking that some people experience.
Aug 6, 2008. 5:27 PMkd1uc says:
Nicely done!! Simple and reusing old technology that still works. There are many old tape players to be had at flea markets and yard sales. One recommendation I would have is to disconnect the motor or remove it for a robotic experiment. The reason is that it draws juice and can add noise to the audio circuit. Some players need the play button to be pushed for the amp turn on. Party On Bill and Ted!!
Apr 2, 2010. 7:38 AMbeehard44 says:
i can use the motor to robotize the amp...
Apr 2, 2010. 2:09 AMbeehard44 says:
anyways, the cheapo earphones are just piezo buzzers (the good ones, you can get strong magnets) and you can just put them (the piezo buzzers) on the soundboard, one under the bridge, one where the fretboard joins the soundboard. then just connectt the negative terminals of the piezo together and each +ve contact to the signal wires of the tape reader. lol stereo. AND they sound better than joining the signal wires 2gether
Apr 2, 2010. 7:34 AMbeehard44 says:
took me some time to get a goo.......er, cheapo earphone thaat uses a piezo buzzer.....
Apr 2, 2009. 7:23 PMfiola says:
I've been trying to make one of this out of a not so old walkman. I think it should work, but the play head is way different than this one so I don't have a clue of where to solder the wires. Plus, I want to solder it to a plug jack instead of directly to the wires so I don't have to tear my one and only cable. I attach the picture of the head. Any help wil be really, really, reaaaaaally appreciated
Apr 6, 2009. 1:38 PMfiola says:
The thing is the head has four contacts on each side plus the one in the center. How should I solder the wires???? Will it work if I solder the wires horizontally so the wire touches the four contacts???? Thanx for the help!!!!
Feb 4, 2010. 11:22 PMomnibot says:
Unlike PyromanicDaniel I think it's a reverseplay walkman, the two extra wires are for the other side of the casette. Prolly it doesn't matter wich pair you use.
Feb 6, 2010. 1:25 PMfiola says:
You're totally right, it is a reverseplay walkman...
Feb 4, 2010. 10:31 PMPyromaniacDaniel says:
I imagine that the player in question is one that can record also and the extra wires are for recording to the tape.
Feb 4, 2010. 10:21 PMPyromaniacDaniel says:
I saw an instructable on using a old folk listening device for a headphone amp and I thought to use an ancient tape deck that one would have laying around collecting dust and here you have already done it for a guitar amp. Very Nice.
You could use a variable resistor in line with the guitar inputs to change the volume of just the guitar down to the tape deck level. be sure to get a audio pot as they are logarithmically adjusted (meaning that it is not a linear resistance but instead is exponentially increased to match our hearing scale)
Nov 11, 2009. 10:15 PMdawgz031 says:
you might have done something wrong with the soldering part...or somethings wrong with the player your using...try tracing where or what you did....you might see whats wrong with it....
im just wondering if some one can teach me or can some one show me how to make a amplifier out of lm324n ic???or if some one can make an instructable about amplifier out of old cd player....
thankz...ill be waiting for some answers.....
Jul 1, 2009. 2:11 PMfiola says:
I finally made it and it works just fine but the volume is pretty low even when having both the player and the guitar at max volume. Also how below guy says there is a ffffffffffffffff sound when playing. Could this things be due to wrong soldering or is just the way it usually goes
May 16, 2009. 2:18 AMxAxrules says:
This is a good Instructable, but I found that when wired to the tape heads, the sound quality was DREADFUL. i would recommend it is wired as a line in straight to the amp in the player.
Mar 27, 2009. 4:50 PMEVHphan says:
could i use a am/fm personal rodio?
Feb 28, 2009. 2:16 PMjeoncs says:
Been looking through these and this is the best no bull with pictures you can see. Thanks!
Nov 24, 2008. 3:32 PMvegettopotato says:
The third clip sounds awesome! I wanna make one of these just for that sound.
Aug 6, 2008. 4:28 PMmvkid360 says:
got it to work! thanks a lot!
Jul 15, 2008. 10:36 PMLeviMan_2001 says:
that actually sounds pretty good!
Jun 8, 2008. 2:58 AMAlex-c says:
I just did a similar project. The results were good except that you could not use headphones. Also, when used a long time, the batteries in the player gets very hot and starts to smell. You can read all about it on the instructable I made.
Apr 22, 2008. 6:59 AMnokkkkky says:
Sup this is brilliant, but only 1 problem i cant get hold of a cassette player anywere and was woundering if maby you knew how or if you could use a cd player
Apr 12, 2008. 8:21 PMIdrisB says:
I built a lot of these a while ago. i used them for a science fair project. I kinda changed the design a bit. im gonna post an instructable on how to do it as soon as i get some pictures.
Mar 11, 2008. 5:43 PMSuper Cameraman says:
I tried this, and it didn't work, but I just tried it again, and it works amazingly! The only problem is that I get a LOT of distortion, and I can't get rid of it. But the good news is that the distortion actually sounds very good! (It would just be nice to have a clean mode every once in a while)
Feb 23, 2008. 8:32 AMpinkpooj says:
I have a headphone jack on my amp, and some Skull Candy headphones, so I won't be making one of these.
Dec 9, 2007. 4:39 PMold_bass_masta says:
Your bridge on the guitar isnt balanced properly, if you are losing tune try balancing it :)
Jan 21, 2008. 2:53 PMold_bass_masta says:
i prefer open e as well, however i am toying with your idea except for the fact i dont have my ibanez anymore :\ but there is a good how to on how to set it up on the fender website,
1-40 of 55next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
42
Author:lennyb
i am a photolab technician and an incurable packrat. i have made swords ,chainmail, crossbows.cameras,bike trailers,kayaks,guitars{slide and electric},knives,various film winders and vacum easels for...
more »
