by a simple shorting block and headers you can 'program' it so the output is:
- only from a single panel (left or right)
- the solar cells are in series
- the solar cells are in parallel.
Remove these ads by
Signing UpStep 1: What you will need.
- A wooden plank (or a project box) to put it in.
- A soldering iron (and solder of course)
- Wires in different colors (just one color will work just as well, but can be very confusing)
- A shorting block and headers (or something else you see fit for the job, if you have enough switches, they should do the job just as well)
- The most important: solar cells.
- Triangular piece of wood (optional: it only serves to make the protecting case)
- Some way to make a variable outfit. I got a gadget key chain at a festival which should charge your phone. It had a cable where you could fit multiple outfit plugs in. but multiple cables should work as well.
- A hot glue gun
- A saw
- A drill
- Sanding paper
Visit Our Store »
Go Pro Today »
thank you very much for your vote!
I have considered other materials, but I really like working with wood. Only the board where the electronics are glued on is a quite dense wood (from a wine case) the protective box is much thinner and lighter. The box parts came from left overs from making a house model. I try to reuse as much as possible.
plastic for the cover could work, but plastics ain't green ;-)
Just google "buy solar cell" or "buy solar panel" that brought me to this: http://sunboy2011.en.made-in-china.com/product/fbUQBlKHnOck/China-5V230mA-Small-Epoxy-Resin-Mono-Solar-Cell.html
but I'm going to the local electronics store to ask their opinion where I could buy solar panels.
ps: The panels in this project are actually barely strong enough to charge my phone but they cant charge iPods or smart phones so you might want to take this into account when buying new ones ;)
If I don't do something productive in vacations I go nuts, so this is really fun to do for me.
