Introduction: Prop Cardboard Buterfly-knife
i will show you how to build a buterflyknife(prop)
you need:siccors or exacto knife,cardboard,a tie twist(tie for garbage bags),a ruler,stapler and staples.
Step 1: Plans
heres the plans you must build 4 pieces the 2 handles,the blade,and the suports.note:2 lines=1cm.
Step 2: The Handles
the handle:u must make 2.it will be 12.5cm long by 3cm wide.cut a small retangle on the midle of the edge and then fold it in half it will now be 1.5cm wide but 2x is thick.put 1 staple at the lower edge.put a hole in the midle of the uper edge of the handle.now repeat this step 1 more time and then you will hae 2 handles.
Step 3: Blade
the blade: cut a 2cm by 10cm rectangle and make the tip shaped like a blade at the botom of the blade but 2 holes 1 at the 1/4 and the other at the 3/4 of the blade.
Step 4: The Suport
the suport: cut a 2.5cm by 2cm rectangle.in the midle cut a 1/3 rectangle on each side.pears a hole with a bin at the 1/4 and the 3/4 at the botom and top of the suport.fold it in half it and it will now be 1.25cm long and 2cm wide.
Step 5: Asembly
u must assemble the pieces like so.u put the hole on top of each other and then insert the tie twist and then thie it in each end.our buterfly-knife is now donne.u can use it in a video,for play,decoration or prank.dont forget u can color it.
