Protable Power Bank
7,815
130
18
Posted
Introduction: Protable Power Bank
this is an easy project to make an 5v portable power bank for just 2$!
Step 1: Parts
The parts you will need for this project is:
* 3x AAA batteries
* 3x AAA battery holder
* 5v step-up
* SPST switch
* Enclosure
* Hot glue
Step 2: Cut the Wires
Cut the wires from the battery holder to the size you want them to be.
Step 3: The Switch
My switch was a little bitt to big so i had to bend the two mounting plates.
Step 4: Soldering
Solder the ground wire to the 5v step-up module and solder the switch to the positive wire, take an red wire that you cut off from the battery holder and solder it to the other pin on the switch and solder the other and of the wire to the positive connection on the 5v step-up module. When you are done whit the soldering remember to test it.
Step 5: Gluing
Glue the module to the battery holder whit hot glue or superglue, I used superglue first but the module fell off the battery holder when i moved it later so I used hot glue instead. NOTE: never ever glue an switch whit superglue! The glue always finds an way to get inside the switch :P
Step 6: Enclosure
Make an nice enclosure for your project! I really want an 3D printer but I don't have one so i made my enclosure out of some hard paper I had.
THANKS FOR VIWING!
If you liked my project than check out my cannel for more cool projects and if you have made one of my projects or have any questions please post it in the comments. :)
  • Microcontroller Contest
  • Spotless Contest
    Spotless Contest
  • Science of Cooking
    Science of Cooking
11 Comments
The 5V step-up which you used are helpful to converting 3.5V to 5V that's whay you used 3xAA Battery but ultimately you are giving 4.5V. Are you not faceing any problem with your step-up device.
Hi guys. Could you help me please with this project? My fully charged 2x18650 butteries doesn't charge iPhone but smart band they does. What the problem?
It might be because your 3v to 5v step up doesent produce enough ampere to charge your phone.
Pretty neat! Check out my diy for a wiring time saver. I bet it would help you, and feel free to vote?
the closer to 5 volt you make the battery pack the more efficient the boost converter becomes so maybe 4 batterys rather then the 3 if you start to use over 5 volt then a ubec would be best they are alot more effecent as they stepping down not up
Nice project, but you should use Lithium rechargeable batteries and use an old power cord to recharge them. BTW, Walmart has those for $9.99, but you would not have had the fun of making yours. :-)
You should NOT be using "old power cord" to recharge Lithium rechargeables, because they might explode.
I don't know why people try to use simple things to charge dangerous and very complex ones. You could charge Lead acid batteries, even Ni-MH / Ni-Cd batteries with simle power source and one resistor, but never try to charge Li-ions and Li-polys with such simple charger, because it might work once or twice, and third time it will explode, when you leave it alone. And trust me, Li-* explosion is quite like not a fun, if not fire, there's lots of awful smoke that is hard to get out of the room, and still furniture smells bad after that.
Peace&Love,
Domints
I have an 3,7v li-po battery on something i made and i connected the battery to an female power jack that I was going to have the input of 5v, is that going to explode? if it is wrong what do i have to do? thanks
Yup, you have to have specialized charger circuit to not to overcharge your Li-po. Li-po's and Li-ions can't be overcharged over 4,2V, because the're going to explode when charged in that way. The simplest but still safe solution is based on LM317 voltage regulator like on that site: http://danyk.cz/li-ion_en.html
And of course you have to calculate the Rx value according to your cell.
An that site there's more complex description how Li-* should be treated to work properly, so it's good to read it all :)
ok thank you :)
