put back patch on vest/jacket
so i have tried to sew a perfect back patch ....but i had to think after many have come out lop sided or even just had big bubbles .. so here is an easy very cheap way to place one and actually have it look god and stay ....
you will need
1 back patch
1 elmers glue or a mid grade house hold glue
tap measure or ruler
2 pieces of card board the size or larger than the patch
and sewing needle / thread or dental floss-works great and stays long time!
Step 1So you have the vest
so you have the vest
take a piece of card board and the vest .....
lay it down flat
take a measure ment to a center area
then tape it on top and bottom
try it on look in a mirror , make sure the distances are at least similar and even is a must ...
3 comments
Sep 14, 2007. 8:17 PMastrozombies138 says:
for removing patches without traces i recomend just exacto-blading the edges, i also made a vest making instructable http://www.instructables.com/id/E95Y0BBF5R8MS6H/ check it out
Sep 11, 2007. 3:51 PMnj snots says:
resistant culture good band other ways to do this would be safety pins, but they don't hold very well and have a higher possibility of coming of. another way is to sew it which is the best way and strongest way to do this but it takes to long unless you use a sewing machine. both these ways are pretty easy to take off if you become unhappy with your back patch latter on in the future and wouldn't end up harming your vest.
Sep 11, 2007. 12:17 PMSouthpole says:
cool ... must be 20 years since i last saw someone with a kutte like that. but what i was gonna ask was if you also have some tips how to remove patches without traces, i have a jacket i need to debrand.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Rorshack
