Put Free Games on Your LG Env2.
Published
Introduction: Put Free Games on Your LG Env2.
Have a LG env2 but don't want to spend money on a game? well here's an instructable on how to put games on your phone.
Step 1: What You Will Need
Step 2: Connect Your Phone and Start Bitpim
After you have installed both the LG env2 USB support software and the Bitpim software plug in your phone via USB or throw bluetooth and run bitpim.
(if you plug in your phone through usb and asks for a sync option choose "DATA")
When you have Bitpim running click edit then Detect phone.
If your phone is detected go to the next step in this instructable. If not then follow along this step
If you get the "run settings" option click "yes" then select these settings.
if you are on a bluetooth connection and are having some problems google some info on bitpim. sorry i did it through usb.
now click okay and try to detect the phone again.
Step 3: Finding the Games
okay now you will need to find some games.
the games you can load onto the LG env2 must be .swf format! i can not stress this enough! here are a couple games that will work
http://www.elpais.com/juegos/swf/pacman.swf
http://www.channel125.com/games/tetris.swf
http://www.digitalbacon.net/games/brickbreaker.swf
once on the website click "file" then "save page as" and save it somewhere you will find it easy later.
now run (if your not already) bitpim. and go to the next step.
Step 4: Getting the Game on the Phone
on bipim click "file system" on the left panel. it might take a minute to retrieve the information from your phone.
when it has retrieved the information you will have collapse menus open them in this order
-flash
--ui
then click "tools"
inside of tools you will find two other .swf files these should be "worldClock.swf" and "ezTip.swf" now here is a disclaimer. YOU WILL HAVE TO SAVE THESE FILES BEFORE MOVING ON OR YOU WILL LOSE THESE. (you can save them if you believe you will need them but in order for you to put them back on your phone you WILL have to lose the game you replaced it with!) to save right click one at a time and save them in your computer somewhere save.
if you didnt understand any of that just keep reading and you will see what i mean.
now you MUST choose what tool you will deactivate from your phone (remember if you save them you can get them back later)
choose what tool and right click it then choose "overwrite" then go to where you saved the game before. highlight it and open.
after it is done overwriting click "data" and "send phone data" and check a box that you dont mind losing info in. i suggest wallpaper because this will only add and not replace. IF YOU CHECK ANY OF THE BOXES THAT SAY REPLACE YOUR PHONE WILL LOSE THAT INFORMATION!
after your phone has restarted you can unplug it then go to menu then setting&tools; then tools and click on ether eztip calculator or world clock (depending on where you saved your game or what game you wana play.
the game should start and pat yourself on the back.
REMEMBER YOU CAN OVERWRITE BOTH AND HAVE 2 GAME BUT YOU CAN NOT HAVE MORE THEN 2.
ALSO IF YOU WAN YOUR WORLD CLOCK OR EZ TIP CALCULATOR BACK YOU WILL NEED TO PLUG IN YOUR PHONE AGAIN AND OVERWRITE YOUR FILE WITH THE FILE YOU SAVED BEFORE.
Step 5:
if you have any questions please comment and or email me at
gravitylb1@hotmail.com
thank you for reading and please comment
    • Woodworking Contest
      Woodworking Contest
    • Planter Challenge
      Planter Challenge
    • Make it Move Contest
    4 Comments
    if you do not see file system, click on view, file system
     Thanks, I didn't see file system and was getting a little concerned as to why.
    I just make sure any phone I buy supports Java and install games with bluetooth, a memory card, or the phone's web browser (last option isn't technically free)... I still haven't figured out what makes Verizon's crippled phones so attractive to so many people.
    It's not so much that we like crippled phones, but in my area, I have better Verizon coverage than any other carrier, and I've tried most of them in the last 12 years. So we do what we must.
