3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
putting together a small survival kit.
This instructable will give a good idea about what is necessary to put together a small survival kit together.
I find these components to be most useful, and customized to my needs. you may wish to change a few things. I feel also that this is better than most commercially available ones. that said you could use a fair few of the things that come in those. and this is also just an opinion, so don't blame me if you get into trouble and it doesn't work for you.
it worked for me when i got lost in the new forest, which is a huge field and woodland area. in the end we walked our way out. 40 miles in 2 days. this kit worked for me so i thought i would share.
Step 1The first thing may be the hardest thing to get!
the first thing may be the hardest thing to get!
a tobacco tin. seriously, Mine is from 1965. In the Uk we don't tend to be able to buy altoids. this is annoying because those tins are really useful, though actually a little small for this. even worse they are made in south wales, but not sold (mainstream) over here. why I don't know. seems pretty stupid to me.
that said once you have one your in business so to speak. i have photos of most things how ever not all of them, but i shall right them down as well. and i shall explain how to use these things, and my reasoning for including them. and what to do with them in the field.
44 comments
1-40 of 44next »
Jun 12, 2011. 7:08 AMmyfacelackseyes says:
I would suggest a using a bic lighter or similar in place of the zippo unless you use/ maintain this kit often; left to sit the fluid in a zippo (or any fluid lighter) will evaporate. You may also want to replace the cotton wool with birch bark (which will light even when wet) and remove the stricker which comes with the flint as a flat blade always works better.
Dec 16, 2010. 2:19 PMBlackonyx2234 says:
Compaq lap top?
i think my mother has the same one
Jul 13, 2009. 12:49 PMrownhunt says:
why did you add a zippo? the fuel will evaporate and all it would do is serve as another firesteel.
Jan 2, 2009. 4:19 AMsmokehill says:
The little Altoids tins are great for very small kits, but are not waterproof. One alternative to consider for a container is a plastic jar, like for peanut butter. Messy to clean out, but absolutely water and air-tight, and weigh nothing. And come in a lot of different sizes.
Mar 29, 2008. 8:25 PMweebs13 says:
(removed by author or community request)
Sep 9, 2008. 2:38 PMteaaddict314 says:
might be a little late for the comment but: "set a trap/get food" it really would be better to use that space for something else, since a person can go about 25-40 days without food, and by then your most likely either rescued or dead.
Sep 14, 2008. 12:59 PMsurvivor569 says:
40 days?!? i think you may need to reconsider your figures.
Sep 14, 2008. 1:09 PMteaaddict314 says:
Sep 15, 2008. 3:30 PMteaaddict314 says:
Sep 16, 2008. 8:04 AMteaaddict314 says:
Sep 16, 2008. 3:22 PMteaaddict314 says:
Sep 16, 2008. 4:17 PMsurvivor569 says:
only ray mears can sort this out. but i agree with F1X0R 40 days is a little OTT
Sep 16, 2008. 5:41 PMteaaddict314 says:
i said 25-40.
Sep 14, 2008. 1:02 PMteaaddict314 says:
some people can live up to 40 days with no food, but average is around 25-30 i think
Sep 9, 2008. 4:30 PMteaaddict314 says:
Food can get morale up, but if you dont catch anything that would probably bring morale more down than getting food would bring up.
Sep 10, 2008. 3:29 PMteaaddict314 says:
just because you know how to fish doesnt mean that you are going to catch anything. If you go out with a professional guide on a fishing trip (say the guide has 30 years experience) you still might not catch anything. Plus what bait are you supposed to use? Fish don't go for absolutely anything, professional fishermen use bait that has worked for them for years, but even then its not for sure for catching anything. You have to take all this into consideration, nevermind the fact that there is no guarantee that you are even going to be in 100 miles of water with fish in it, and the fact that the chances of you catching anything for shore is not very likely at all since fish are usually way out there...
Feb 3, 2010. 6:36 PMfranklinonline says:
 if you have a stream where you can see fish, and you dont care for the enviroment, you might be able to shoot the stream/pond, and the shock will kill the fish inside. Better than using bait as its more garenteed. But there wont be fish anymore
Sep 11, 2008. 3:24 PMteaaddict314 says:
Snares arent very good for getting animals either, granted they do work, but they are not too effective...
As for thinking one dimension, not to be rude but I think my kit is more multi-purpose than yours.
Jan 2, 2009. 4:07 AMsmokehill says:
Guns are far better for getting game, but sometimes not allowed in certain areas (Nat'l Parks or Forests, some State forests). There are a couple of survival guns designed specifically for this -- the AR-7 probably the most popular (and cheap). It comes apart in a couple of seconds, and all the parts fit inside the foam-filled stock -- and it floats! It's a ten-shot .22, not much good for bear protection, but great for small game like rabbits, birds or squirrels. As far as fishing -- if you're anywhere near water of any size at all, there's probably fish there, even if small ones. I'd like to see a small mesh net in the kit since it weighs nothing and takes up no space. Even in tiny creeks there are usually frogs or crawdads (crayfish) or salamanders. Not appetizing, but better than worms or grubs. Bait should never be a problem. Poking around in dirt, leaves, or in dead, rotted trees, should bring up tons of bait, and fish will bite faster on that, or worms, better than on fancy lures. Another thing I like in a survival kit is a good-quality Swiss Army knife, either Wenger or Victoninox (most other brands are junk). I wouldn't be without a very high-quality hunting-type knife, but there are a lot of handy little things in the Swiss thingie -- saw blade, toothpick (for cleaning wounds & splinters), can openers, etc. The ideal survival kit is probably about the size of a steamer trunk, and we have to be realistic -- but depending on the area and conditions, I'll usually put up with "more & bigger" just in case .... One of us usually carries a cheap plastic flare gun (from boat supply places), so if we see someone looking for us, like in a plane or chopper, we can signal them. We've always figured it might be a great defense against bears or cougars, too. Magnesium burns into the critter and keeps on burning for several minutes. Nobody usually mentions map or compass in these kits. A GOOD compass costs about ten bucks, and is worth every penny. Good, detailed maps of most areas are usually cheap, sometimes free -- you should never be in the boonies, especially if you don't know the area well, without a map.
Sep 12, 2008. 12:45 AMteaaddict314 says:
and i never said snares didnt work, they just dont work very well considering they can take a couple of day, and usually people are rescued in a couple o days anyways
well when i originally said the first statement i was talking about the hooks, but then i got a little bit sidetracked to the arguement of catching food being important or not and the likelyhood of actually catching anything
Jan 2, 2009. 4:11 AMsmokehill says:
Yes, and bringing a LOT of hooks is important. You can lose them on snags, etc., very easily. They are cheap and weigh nothing. A couple of little lead sinkers is handy, too. Tying rocks onto fishing line is a real pain. If you have the space, a bottle of salmon eggs stores really well, and is good bait for almost any fish -- probably 50 "baitings" in one little bottle. Saves having to dig for worms & grubs
Sep 14, 2008. 12:56 PMsurvivor569 says:
i carry my compass on my watch. nice one! i have one of these but i fit it all in the box from my NATO fire lighting kit.
Apr 27, 2008. 3:47 AMzorro3355 says:
pretty neat.and go wipe your screen!
Apr 9, 2008. 5:58 AMsteelcap77 says:
Tampon is a GREAT idea. I like trick candles since they do not blow out in the wind. Thanks for the tips, as I'm always looking to upgrade mine.
1-40 of 44next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:F1X0R
