3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
pvc roof rack
pvc roof rack
  • last photo ←
Firstly, the idea to do this came from terribly overpriced roof racks.
Mostly 350.00.
After a couple of hours of looking at what Lowes had to offer I chose these.
50 ft of 3/4 inch schedule 40 sprinkler pipe, 20-3/4 "T" connectors, 8-3/4 pipe to 1/2 threaded connectors, 8 special adapters called "Universal" for disassembly, and the corners are 3/4 90 degree angle with the 1/2 threaded offset X 8, to give the roof rackyour choice of height.
Total cost 45.00.
Step 1Measure as you go
Measure as you go
I built this roof rack one measurement at a time. Keep in mind that as you measure, depending on where you want to put fittings for support you will have to count the inside measurement of each fitting otherwise it will be short.
23 comments
May 6, 2012. 5:04 AMjoeb1kenobi says:
PVC is probably too weak for roof racks which get tremendous dynamic stress from turning, stopping, starting and wind resistance. It's better to shop around craiglist or amazon for a used metal rack with secure mounting points.
Sep 21, 2010. 8:37 AMthewetturd says:
I know this is an old instructable but I wanted to comment on something if I may. First thing, good job on the idea and the effort that you put into to it. I have a homemade rack for my Corolla that I use for upto 3 kayaks that weigh a heck of a lot more than your bike. I haven't used PVC though. Not that I didn't consider it. There are several issues with PVC. Firstly, the white stuff does not have UV protection and it becomes brittle when exosed to sun and heat over time. The grey one is for electrical conduit and can withstand the UV a lot better and if it is painted with plastic compatible paint, well that's even better. Secondly, the white pvc can also comes in smaller thicknesses than schedule 40 which should not be used for structural projects at all. Thirdly, I would not trust the pvc cement for structural builds either. It makes a good bond but over time and stress it will fail. It's just a matter of time. Its better to use small stainless steel pan head screws in conjunction with the cement to screw the fittings to the pipe where they overlap. Remember to pre-drill. Lastly, in my opinion, structures like your roof rack should not be elevated off the car's roof. This design puts a lot of leverage tension on the structure and eventually can "cause failure. If this rack is to be used as is, it should have a "belly" strap that goes through the car doors and around the entire rack and bike so that if it all fails it doesn't end up falling completely off the car and in to traffic. Good luck and be safe out there. Again, I commend you on your intructable and ideas.
Mar 2, 2007. 12:29 AMVisitor says:
Toyota Echo: $10000 Tandem recumbent bike: $2000 Hacked PVC pipe roof rack: $45 Safety of other road users: priceless I apologize if I sound a bit offensive, but I think you are trying to save money in the wrong place. A basic roof rack from a quality brand manufacturer costs about $150. And if safety of others is of no importance, there are the liability issues. Also, where I live, transporting stuff on the car roof without an approved roof rack is illegal.
Jul 11, 2009. 9:37 PMfreema0720 says:
Seriously? Bite it. This car top carrier is no less safe than the commercial models sold for hundreds of dollars elsewhere. It sounds like someone owns some stock in a car top carrier company. AND this is a site about hacking (in the finest sense of the word....workaround solutions that save money and are more efficient) so if all you're doing is trolling the site to maliciously attack people, go home! Finally, and take it from me, I get paid to make people laugh, that Mastercard/Visa thing is Soooooooooooooooo played out. Couldn't you have come up with something more clever? Remember this too....people who live in glass houses shouldn't throw stones AND they should probably go to their neighbor's house to go number 2. james freeman
Jul 12, 2009. 8:32 AMVisitor says:
In May 2007, when I wrote the comment, the MasterCard joke was still funny. Times have indeed changed since then. You should read the post dates before commenting. I hope this helps. Have a nice day!
Jul 14, 2009. 12:14 AMfreema0720 says:
*lmao* OK, you have a point...The MasterCard jokes WERE funny back in 2007.I should tell you that I'm not a frequent visitor to instructables and the comment left in reply to your comment was not written by me. My little brother used my account so he could download the .pdf flies he needed to work on his project. He must have run across your comment and, as he all too often does, put his foot in his mouth. Please accept my apologies for his rudeness as he isn't the type to admit his mistakes. ALL of that being said and despite the fact that he stole one of my better jokes,and for some inane reason signed my name (my full stinking name!!!!! I ought to give out his ss number) he had a point (not about the MC joke, that's all yours brother!) Now that I've read the original comment myself it DOES seem a little mean-spirited and unnecessarily pejorative. Also, I have a dock with 8, 2 inch pvc pipes and they've held up for a couple of years now with rugged and frequent dock use, so I'd have to take some issue with the idea that PVC isn't strong enough to safely support a bicycle. Still, it was none of my brother's business and it's certainly not mine so again, apologies offered. To each his own, live and let live and all that stuff right? Dell Netbook 345.00 Monthly Internet service at a blazing 20mbs 40.00 A joke that never really goes out of style? Priceless remember this too a bird in the hand is worth more than 2 in the bush. But the bird in your hand can go potty in it! Two wrongs don't make a right. Noooooooo but 3 lefts do!!! Some people see a glass half filled with water and call it half empty, others call it half full, personally I ask for a refill. I mean what the heck am I paying for here? and finally, they say the pen is mightier than the sword but you only get to read about that kind of stuff because anyone who brought a pen to a sword fight is dead!!!!! Have a blessed and peaceful year man jf
Apr 8, 2009. 6:56 PMSwishercutter says:
My Yakima rack I bought for my 97 Civic Hatchback was around $600 with all parts, then again I paid retail in 1998 for it.
Mar 2, 2007. 2:24 AMRavinss says:
I'm actually interested in acquiring a basic roof rack from a quality brand manufacturer myself and would be interested in this $150 option you've found. The only options I've run across so far have started at $245... and as tempting as it sounds, I'm not sure I quite trust the PVC (or my ability to construct something I'm willing to trust) I did a quick check to see how much it was for a tandem bike mount... $369... and that's after the $245 to install the basic towers and cross bars.
Feb 23, 2008. 3:17 PMhazarddan says:
There is an wise and affordable alternative, to the 500.00 rack and the PVC rack. The company is TYTErack.com. they make a rack for tandem, cost is under 200.00 (no hidden add ons). You get, the four towers, the 2 load bars and bike hardware, they also manufacture a rack that will carry standard bikes for under 100.00. All the racks sold are universal in attachment meaning that they fit any car. The racks BOM is USA and certified, Military spech bike holders, USA fully traceable fasteners, USA steel with a triple layer powder coat that will resist rust 5 years past a THULE or yakima, check it out,
Mar 2, 2007. 11:20 AMpdamer says:
Google for toyota roof rack found this site:
http://www.racepages.com
They have a basic roof rack for the echo for 135
looks like they have options for all kinds of cars.
Mar 2, 2007. 3:24 PMtrebuchet03 says:
Not mine :P And there needs to be more emphasis on quality.... After searching around a few forums... Two brands of roof bike racks were recommended for my car.... OEM and Thule.
Thule 594 - Thule Sidearm (to mount bike - really can't forget this part): $130.50
300 - Thule Rain Gutter Foot Pack (for roofs with rain gutters): $121.50 (400xt upgrade is $4 more)
LB50 - Thule 50 Inch Load Bars (to attach to feet): $49.50
Which comes out to $301.50 - still cheaper than OEM and I have read/seen almost no horror stories compared to their competitors. I think a friend of mine still has a Yakima mount system for sale -- it's broken, but cheap :P
To be honest, I wouldn't be worried about the PVC whatsoever -- it's the mounting system that needs special attention ;) My platform bed is supported on 4 PVC tubes - my bed by itself weighs 300lbs(mattress + floating frame) + 2 adults (an additional 250-300lbs).
Nov 11, 2007. 9:49 PMsmokehill says:
"My platform bed is supported on 4 PVC tubes" Yes, and that's a pretty good application for PVC pipe -- the pipe is supporting the weight in compression, which is very strong compared to its tensile strength, and it's inside, where it won't get exposed to UV or cold temperatures. In compression, I've even used PVC outside. Some of my pigeon & chicken houses have 2" PVC legs, like your bed, and have been holding 7-8 yrs so far, outside and largely immersed in very high-acid chicken poo, which will rot or rust almost anything. However, failure isn't a big worry there since the structure will only lean over a few inches at most. I haven't built a roof rack in 20+ years, but I don't see why someone doesn't just make it out of 2x4's (with some paint-friendly spacers) rather than PVC, if money is the issue. Properly-built wood structure I'd trust up there on the rood, but not PVC.
Mar 2, 2007. 7:57 PMmje says:
As others have noted, PVC pipe does not have the strength for this application. The box you've built is likely to deform and eventually crack at highway speeds, leading to the loss of a very expensive bike and the injury of someone behind you. If you're looking for inexpensive construction material, a better choice would be steel conduit, which can be bent, and has a wide range of fittings that can be attached with screws. But if you're carrying a $3000 bike, it seems foolish economy not to spend what it takes to buy a proper rack.
Nov 11, 2007. 9:28 PMsmokehill says:
I tend to agree that PVC may not have the strength necessary, especially if you live in a climate where the temperature drops very low in the winter. I use PVC on my work trucks, and whether it's cumulative sunlight exposure, or just the temperature extremes, we crack 2" PVC all the time in the winter, just by laying it on the pavement (not dropping it, just laying it down less than gently), usually when it's about 25 degrees F. For this reason, critical tank & plumbing parts on our trucks are METAL, not PVC. Not worth a large HazMat spill, for sure. I love PVC and use it for a lot of stuff, but one has to keep its inherent limits in mind ... sort of like Dirty Harry used to say: A pipe has to know its limitations."
Apr 29, 2008. 8:10 PMbigwhitebob says:
Safety Third!! I wouldn't use it every day but its a good system in pinch, I would be more concerned with the metal conduit then the pvc, its not stronger unless you increase the number of cross bars and it would seriously damage the paint (on the car and the bike). I like the PVC Moddy, Make on!
Jun 14, 2007. 4:38 PMphilreeper13 says:
could you use this for a surf rack instead of a bike rack?
Mar 2, 2007. 6:56 PMtstens says:
I drive a Hyundai Accent, and I purchased a generic removable roof-rack from the local auto parts store for about $75. It just sits on top of the roof and has brackets that hook on the roof inside the door. When you close the door, it holds the brackets down. Although I don't keep it on the car all of the time because it kills my gas mileage, it's saved me countless times from having to pay for delivery or enlist a buddy with a truck. I just hauled an Ikea bunk bed set on it yesterday (not assembled, of course).
Mar 1, 2007. 9:36 PMsirwilliamjr says:
I was thinking the rack sounded like overkill (compared to just using a trunk rack), and then I saw your bike. Looks like a pretty good idea, now :) You could probably tell just by pulling side-to-side on the rack whether or not it would be needed, but I would try to add some diagonal ties or braces, since your bike looks heavier than usual and the rack is so tall. Taking a turn too fast could put a lot of torque on those t-fittings. Like I said, may be plenty stiff as it is, though. Either way, nice solution to an interesting problem!
Mar 1, 2007. 8:12 PMtrebuchet03 says:
Nice 'Bent! Is that a Rans Screamer (can't see from this angle)?
I do think you need some lateral (side-side) support for that unavoidable evasive maneuver. A strap should be able to go right in between the door frame and weatherstrip without much trouble. Or, it could go down to the chassis with a hook (most cars have a little ridge just under the rocker panels).
If anyone is paranoid about scratches... Pipe insulation from the hardware store ;) It comes as split loom with adhesive tape and cuts very easily. I can't remember a price, but I'll bet its around $5 for 4 feet.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Moddy
Idabble@yahoo.com was taken, or otherwise I would like that email. It describles the vast reaches of my experience or understanding. I can deduce answers for problems as people tell me. I learned how...
more »
