pyro system
 by budsiskos
video pyro system
instructable coming soon
concept credit to everrett bradford
ajax63135 says: Jan 20, 2013. 3:25 PM
could you email me the instructable. im really anxious to try this.
The 4th Doctor says: Oct 22, 2009. 6:58 PM
wow you really got the whole trigitron ignition working well, ive wanted to make an instructable on that but i always have so much trouble with it (i use it on my potato cannon)
pyroninja21 says: Oct 14, 2009. 1:08 PM
gshoppe could you post an instructable on your version plz
gschoppe says: Oct 11, 2008. 12:48 PM
If you want a more reliable ignition, use a negative ion generator (available at electronic goldmine)... you can get a continuous 1/4" gap from them... its what my version uses, and my ignition is 100% reliable.
Morhion in reply to gschoppeAug 18, 2009. 5:51 AM
The ion generator offered by that website uses 120VAC. Would it work with just battery power?
gschoppe in reply to MorhionAug 18, 2009. 5:56 AM
they offer two generators... one is rated for 120VAC the other for 12VDC... the 12VDC model will run fine on 9VDC from a battery, or 12vDC from an N type security battery (for short runs).
Morhion in reply to gschoppeAug 18, 2009. 8:43 PM
Ah, ok. I only saw the 120VAC version. Thanks for the info.
budsiskos (author) in reply to gschoppeOct 12, 2008. 8:21 AM
but arent those usually powered by 120 ac? the system i use is reliable enough for what it does though
gschoppe in reply to budsiskosOct 12, 2008. 7:54 PM
the one from electronic goldmine is 12Vdc, designed for car uses... it works great off 9-18v from 9v batteries
budsiskos (author) in reply to gschoppeOct 12, 2008. 8:03 PM
might be interesting to try. ill look into it or you could try it when they finally post my instructable
shabaki says: Jul 11, 2009. 6:04 PM
sweet but u should try things such as putting the nozzle or the butane at an angle up maybe 35 degrees? that way you can tilt your hand/wrist down and it still shoots straigh making less fire hazards and opening up an oppurtunity for a larger flame
Thelonelysandwitch says: Oct 17, 2008. 12:47 PM
what do you use as a fuel
budsiskos (author) in reply to ThelonelysandwitchOct 17, 2008. 1:09 PM
butane refils
Thelonelysandwitch in reply to budsiskosOct 17, 2008. 1:11 PM
if you put a tiny piece of copper in the flame, it will turn green. thanks
budsiskos (author) in reply to ThelonelysandwitchOct 17, 2008. 2:28 PM
awesome. will try
maxpower49 says: Oct 2, 2008. 2:58 PM
when will you be posting an instructable
budsiskos (author) in reply to maxpower49Oct 2, 2008. 3:50 PM
ive alredy published it but its not showing up. ill be pm-ing someone soon
Decepticon says: Sep 27, 2008. 3:44 PM
Oh man, I can't wait to see the viral videos of this kid burning his house down or setting himself on fire!!!! Neat invention though. Now all we need are some supervillians!
jakee117 says: Sep 26, 2008. 3:37 AM
sorta like Tetranitrate's flame slinger...
budsiskos (author) in reply to jakee117Sep 26, 2008. 6:41 AM
sorta but the ignition is a spark instead of an open flam, and everything goes on the wrist(no fuel in pocket)
jakee117 in reply to budsiskosSep 26, 2008. 12:14 PM
ahhh ok cool that is a good design
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
