Introduction: Python :Linker_Button
Picture of Python :Linker_Button
Linker button is the key, the SIG(signal output port) of linker button is at a low level(logic0)in case no button
pressed, after the button press, SIG will output a high level (logic 1). And pcduino GPIO through testing
linker button SIG level to determine key state.
In this post, we will demo how to control the linker led through linker button.
Refer links:http://learn.linksprite.com/pcduino/pyhon/python-%EF%BC%9Alinker_button/
Step 1: Part List
1. pcDuino V2   x1
2. Linker Button  x1
3. Linker LED    x1
4. Linker Base  x1
5. Linker cable  x2
Step 2: Wiring Diagram
Picture of Wiring Diagram
Step 3: Test Code
import gpio
from time import sleep
led_pin = "gpio2"
button_pin = "gpio3"
def delay(ms):
    sleep(1.0*ms/1000)
def setup():
        gpio.pinMode(led_pin, gpio.OUTPUT)
        gpio.pinMode(button_pin, gpio.INPUT)
        print " Linker LED Pin : D2 \n Linker Button Pin : D3"
def loop():
        while(1):
                if(gpio.digitalRead(button_pin)):
                        gpio.digitalWrite(led_pin, gpio.HIGH)
                else :
                        gpio.digitalWrite(led_pin, gpio.LOW)
setup()
loop()
Step 4: Test Result
Picture of Test Result
About This Instructable
519views
4favorites
License:
More by Yanny Guo:Use pcDuino as Photo Booth ControllerUse Si4703 FM Breakout Board on Arduino UnoUse SIM900 GPRS/GSM Shield on pcDuino
Add instructable to:
