loading
Picture of Tyco RC Arduino Robot
Wanted to make your own robot but couldn't afford the fancy H-Bridge IC's or etch your own PCB? Want a quick and dirty method of making your own wheeled robot? Then you're in luck, but if you want to make your own wheeled robot AND have a quick and dirty wireless controller for anything then you're REALLY in luck.
Required Items:
1 Tyco RC Air Rebound
2 Philips Screw Drivers one smaller than the other one, I don't know the sizes of the ones I used.
1 Arduino Uno
1 Soldering Iron
Plasticard (Not used, but will be used in an update)
Step 1: : Removing Power
Picture of : Removing Power
Switch the RC Car off and remove the battery by flipping it over (Switch facing down) and rotating the latches, and flipping the cover down. (If the car has already been switched off, or the battery removed, proceed straight to step 2)
Step 2: : Removing the drive wheels
Picture of : Removing the drive wheels
Grip one of the two drive wheels with one hand (To keep them from moving) and with your free hand use a Philips head screwdriver to remove the wheel (Repeat for the other wheel)
Step 3: : Removing the big wheel
Picture of : Removing the big wheel
Grab the smaller of the two sides (if you have the battery compartment facing up and towards you, it’ll be on the left) Start unscrewing the front wheel (The green one). Once you’ve unscrewed that side flip it over and unscrew the other side.
Then flip it back over so the smaller of the two sides is facing you.
You should see five screws (Four in a square and one in a deep hole) remove all the screws then gently remove the side bar and the main wheel.
Robot Lover3 years ago
Instead of going to the trouble of making a motor controller and all that jazz, why not just take a few 5 volt relays and connect them to the remote control, then all you have to do is power the relays from the arduino pins, and you dont need to mount your arduino to the robot!
Dominion-Network (author)  Robot Lover3 years ago
Then it'd still be an RC car and not a robot, I have plans to upgrade this in the future with a ping sensor and / or IR distance finder / Line Follower upgrade.
Could you not also connect the original controller up and hook it up to inputs on your arduino, making it RC AND robot? Like program it to override your control when you try to crash it into an object, and have the option of full autonomous mode, etc?
emdarcher3 years ago
Aw man, i have the smaller version of that same car and the arduino will not fit on it. :(
what if you used a arduino mini or a small teensy board?
I may use one of my ATtiny85s I have laying around.
nerd74731 year ago
very cool I love it when people upload code since I am not good at it
really cool! to bad I don't have Arduino. that sucks!
I recommend getting one they are cool
bill20093 years ago
very nice. And well explained. You should have a look at the "makey" robot code, some of the sketches for it could give you ideas. Consider some ping-type sensors for obstacle avoidance.
How fast will it go?
Dominion-Network (author)  bill20093 years ago
Before I slowed the robot down, it would go so fast it'd smash into everything and do a couple of flips, so obviously I had to slow it down, and I'm already a head of you regarding the ping sensors / other upgrade options as I'm currently working on converting the robot base into a line-following robot.
LOL on the speed. I ask about that because I built my own carbot as a wall-following racer and I was thinking maybe we could hold a competition: Agree on a track, post videos and times. http://arduino.cc/forum/index.php/topic,8756.0.html
i'd be interested in the line following upgrade - i have not done that.
I checked out the link you posted, looks pretty good, you should reverse engineer it and show everyone how you put it together.
mycroftxxx3 years ago
Any chance we could see a video of your bot in action?
Dominion-Network (author)  mycroftxxx3 years ago
Here's the video, I apologise for the crappy quality.
http://www.youtube.com/watch?v=a9kC4_-FFjE
I've got some demo software worked out, I'll be controlling the robot via USB on my laptop, but the current state of the robot has a horrible (Almost impossible) turning circle due to the big green wheel.
I'm currently working on some code that will allow me to control the robot from my pc, unless I 'program' a path for the bot to follow for demo purposes.
