3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
"The Quick Fix" Flip-Flop Blowout solution WWMD
If you got some slide in your glide then things like this can happen. One minute peaches and cream the next bam blowout, but don't get down, there is now finally a solution to repair those favorite flip-flops and regain that pep in your step. Always remember in the time of despair always ask yourself,"WWMD" what would McGiver do.
Step 1All you will need
All you will need
1)a piece of string (nylon if possible because it is thin strong and won't wear that fast and can be melted.)
2) a washer (a couple times larger than the hole and flat as possible)
The purpose of this instructable is to get the fastest, easiest way to get back in commission.
9 comments
May 22, 2012. 5:25 PMbelievenyourself says:
Easier to find a safety pin. Just put it back thru the hole and place safety pin thru the tip so that it makes it not slip back thru. You're basically making a little stopper with the safety pin so it won't slip back out. good for a quick fix
Feb 15, 2009. 2:40 AMjianqiang says:
I grew up wearing rubber slippers(flip flops.....) and when they would pop out, I would stick the bottom part of my shirt through the hole, stick the numb'n in the shirt part, then pull. A fast and temporary solution is a saftey pin.
Aug 18, 2011. 5:53 AMNOODLE! says:
whaa...?
Jan 6, 2009. 5:11 PMskidude28 says:
Hmm, what are the chances you or one of your buddies would have nylon strong or a washer with them? Good idea, but I was hoping for a fix-as-soon-as-it-happens type of instructable.
Jan 11, 2009. 3:28 PMskidude28 says:
Oh wow I spelled 'string' wrong.
Jan 7, 2009. 5:07 AMlasersage says:
a cheap pair of animal sandals i had broke while walking up a big hill, found a cable tie in my girlfriends bag and fixed it (she's a handy girl). Further up the hill the other one broke too, damn animal, all out of cable ties managed to sort it with a key ring! All it takes is a little imagination :)
Jan 9, 2009. 7:23 AM999592 says:
lol
Jan 7, 2009. 10:06 AMskidude28 says:
No... Absolutely not.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:jedbd
