Step 3Hollow out your monitor.
- Use a simple screw drive and remove the main support screws. Odds are that its a philipshead.
- Carefully pull the case apart until you can see the actual machine part of your display and lay it upside down with the glass part facing a soft surface... in this case i used my bed. Then proceed to unscrew the re-inforced corner supports that join the display to the case and carefully separate.
- once you have skinned your cadaver, clean up accumulated dust and let it air.
moving on ....
Add Comment
