Step 5Cut,cut, cut !
you will also probably need to use styrofoam or cardboard cut outs to create support for the heavier components of our project ( i.e: sub, digital frame, digital alarm clock. ]
be careful and if you care for your outstanding physical features i advise to use protective safety wear [ just because it never hurts to be safe ]
once you've done that, make sure you polish up your work so it looks clean and presentable [using sandpaper among other things is a good start ] but if you like your work rugged-looking and beaten up, be proud of your dead electronics and display your work that way too. the options are enless. if you have spray paint or anything you can make some grafiti or customize your case in any way you want.
Add Comment
