Step 2Add the snout and jaw!
Cell-u-clay
aluminum armature wire
pourable plastic resin (optional)
resin epoxy glue
hot glue
okay so I skipped a few steps, here..im sorry! Basically I formed a little wire armature for the snout, you can see it running along the sides there, nice and ugly. I then glued it down with the epoxy and glued some foam over the wire armature with hot glue. Snip the foam snout down to the shape you want. Make it a little skinnier than needed since we are going to add to it.
I then coated the entire thing with resin to make it super strong!
Mix your celluclay and create a basic snout. Let this dry for awhile.
i'm english and it seems a little harder to come across all the required bits (unless i want to ship from other countries) but i was just wondering what exactly it is you use to coat the bits and pieces to keep them solid and protected?
Im trying to make the same costume, and its going very nice and smooth because of these great advices, but i just started wondering, cause i used some fence wire to make my snout wich i thaught would work just as good as any other. But then i got worried about the wires i mentioned. Yes i know i talk too much.
