3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Werewolf costume
Step 6Make some paws!
make some paws!
You will need:
Baseball batter's gloves
epoxy
dremel
Plastic craft claws
foam
scissors
needle n' thread
fake fur
armature wire
opera gloves
acrylic paint
clear polyurethane
Foam over a baseball batters glove. Hot glue it on. The wires will make the claws sturdy on top of my fingers ( the claws will fit over the wire, create a hole in the claw with the dremel tool). The foam makes my hand look like it has different stubbier joints and hopefully a little less human.
Glue the claws onto the finger wire with epoxy. Paint your claws and seal with the clear epoxy. I painted the paw pads first with the latex to reduce to pores of the foam, the went over that with black tool tip. ( there are better ways to make paw pads but this is what i did) I shaved down the finger tip fur and let it fade into longer fur on the back of the hand.
Cut the fingers off of the opera gloves, put one on and insert it into the glove. Using hot glue...yes, hot glue...glue on strips of fur up to your elbows. The trick is to use a low heat glue gun ( NOT the large high heat!)...apply your glue onto the strip of fur, let it cool for a minute and then apply it to the opera glove. It will be warm but won't burn you. You just need it to stick enough to hold in place. Once all the fur is attached, remove the opera glove with the paw still attached and sew all of the fur seams together. Lower arm done!
16 comments
Sep 24, 2010. 11:54 PMferalucce says:
We're making one and have found that contact cement works better than hot glue... it sticks to everything and is STRONG
Dec 18, 2010. 5:28 PMMotts says:
I can testify for feralucce, contact cement is really the way to go.
also, is there foam on the back of the paws too? Where is it placed?
Sep 18, 2010. 10:41 PMReptle says:
I'm curious by the direction of the fur you chose. I'm having the same problem with the muzzle.. in all realism, shouldn't the fur be going down the arm itself, rather then up?
It probably gives it a more scruffy look that way I suppose. I'm still debating it. Gonna do a mix i think. Paw itself being upwards, arm being downwards. it'll hide some of the glue I'll use for the details between both.
Jun 26, 2010. 9:34 AMInumo says:
Probably gonna be a year or two before I have the moneys for this, but... From what I know, hot glue stiffens up once it dries. Did you use some kind of specialty hot glue instead to make sure you could still move your hand around, or did you just use normal hot glue because it wasn't a problem?
Jul 12, 2009. 2:54 PMUmbrahound says:
Where did you get foam like that? Ive never been able to find thick foam.
Jun 5, 2010. 4:11 PMholidayfreak says:
camp pad.
Jan 18, 2010. 10:45 PMlironess says:
They have the foam at Joann's Fabric or at other places that sell stuff to do upholstery.  You do not have to buy a full sheet at Joann's just look for a smaller piece that is left over from someone else. I get a couple of feet at a time. They will also cut a big sheet smaller for you.
Oct 1, 2009. 1:20 PMSlashmasterAeoniX says:
This picture fits perfectly with the sign in back....XD *Employees must wash hands...
Aug 15, 2009. 1:47 AMErnestoGP says:
why is the fur violet/pink in the fourth picture?
Aug 25, 2009. 9:21 PMJilliquin says:
I think you're referring to her own hair, which is bright pink, or was at the time.
Sep 1, 2009. 7:18 PMErnestoGP says:
I meant the hair on the arm & paw.
Aug 20, 2009. 3:24 PMtenayaisapunkrocker says:
how did you change the color of the fur?
Oct 19, 2008. 9:37 PMlironess says:
Makin the paws this year! Did you foam the top of the fingers too or is that just fur on there?
Oct 2, 2008. 1:15 PMchatake says:
Hey! How did you make the claws? Or did you buy them?
Oct 14, 2008. 4:06 PMjancola says:
I *think* the claws are the plastic ones used in kid's crafts, like for stringing necklaces. Google product search "Plastic bear claws"
Oct 5, 2008. 7:14 PMlobo_pal says:
Where'd you find such long fur?
Aug 1, 2011. 9:44 PMlironess says:
When you made the paws, I can not see how you wired the claws on, it is hidden by the foam......I'd like to see it or hear from you. Wonderful costume. I love to show this to my friends who love werewolves.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
131
Author:missmonster
I'm an artist from Texas who now lives in Chicago. By day I work at a large phone company doing graphic design. On the side I freelance, making paintings, sculptures, and exploring as many mediums as ...
more »
