Rebuild Google Cardboard
Published
Introduction: Rebuild Google Cardboard
im rebuilding my c-board to fit a larger phone
since my phone is 5.5" it did not fit inside
you find many good/ugly hints how to do this. but they do not work
so i made a complete overhaul of the look
its semi-complete (there are things i still can do to inpove it but for the tuturial i let it stay like it is)
Step 1:
cut the remaining cardboard that came with the case like showed. (i used a pencil)
Step 2: Adding Durability to the Original Case
you can add some tape and dual sided tape to inprove stability and prevent sweat damage
Step 3: Inproving the Sides
use the made new bottem and some cardboard
in the size of the sides of the original case
then use tape to fix it togher
use a pencil to mark the location of the bulking out part of the side.
scratch over it with a pencil to make it deeper
Step 4: Finished
this is the finished product.
things that still can be done:
painting
adding more stability
adding more shape
my mod-log at bit-tech.net
http://forums.bit-tech.net/showthread.php?t=285028
if you like this please vote on the RE_USE contest for me
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    2 Discussions
    its also better than the regular modded ones, its more sturdy. (only down-side is that i still need to config the factor for the QR-code for this mod)
