Introduction: Recycled Pallet Note Pad Chalk Board
have a note pad handy where ever you need it. Not only does it use recycled pallets but also saves on paper note pads Simple to make and fun to use
Step 1: Things I Used
TOOLS Pallet wood (1/4 sawn)
Table saw spar varnish
Hand plane mini railroad spikes
Drill press chalk board spray paint
Sander old leather belt
chalk pencil
Step 2: Be Carefull
Working with power tools and sharp hand tools is fun but use your head also wear safety glasses as well as a dust mask
Step 3: 1/4 Sawn Oak From Pallet Cut Down on Table Saw to 1" Thick Boards
I started out with a 3x4 piece of 1/4 sawn oak after I milled the board down to 1" thick boards I looked for soom good figure to cut out my pieces for the note pad
Step 4: Thickness Plane and Flatten Out the Board
using a block plane I flattened out the boards that had already been cut on the table saw.
Step 5: Cut to Size
After cutting size I sanded down to 220 grit and beveled all the edges
Step 6: Drilled the Peg Holes
Step 7: Make a Square Peg Fit a Round Hole
I used my block plane to round of the peg and beveled the end with a belt sander
Step 8: Varnish
after sanding I used spar varnish to bring out the figure in the oak.I used 3 coats with a light sanding in between
Step 9: Paint the Black Board
I used chalk board spray paint First I taped it out leaving a little edge on the front leaving a little edge unpainted to make it pop
Step 10: The Chalk Holder
I used an old belt to make the chalk holder I cut it and nailed it on with model railroad tacks
Step 11: All Done Ready to Leave a Note
Step 12: Be Carefull
use power and hand tools with care they are fun to use but dangerous also safety glasses and a dust mask
Green Design Contest
