Introduction: Redone Killerk Magnum
This is my first instructable, sorry if it isnt great, i tried hard on it.
anyways i made the killerk magnum and decided there are certain things about it i didnt like, or i thought could be improved, and so i did that. The end result was a extremely fun to use and more rifle-like magnum. i made it with the intent of trying to make it magazine fed. that idea failed, but im still trying!!
NOTE: THE BASE MODEL IS NOT MINE, I AM NOT THE ONE WHO MADE IT. I ONLY HAVE REDONE IT AND UPGRADED IT.
ALSO- i am not responsible if you have so much fun with it your face melts off.
Step 1: Making the Barrel and Frame Top and Bottom
Basically all you need to do is make these pieces EXACTLY LIKE PICTURED and set them aside. you will have more pieces to make before you need these again
Step 2: The Support Pieces
You must make these pieces. they are the support for the gun, without some of them the gun will bend and you will have to use weaker rubberbands. you must have to of every part. you should be able to just look at them and figure out what parts to use
Step 3: Time to Put the Barrel and Body Toghether With the Support Peices!
ok so now what you do is you put the pieces together. the pictures should explain it pretty well. sorry if it doesnt
Step 4: Frame Construction Part 2
ok this is part two of the frame construction. its really simple and easy to do, just look at the pics
Step 5: Making the Trigger-stop and Reinforcing Handle and Frame
just put these pieces where it shows to in the pictures. if you need to go back to the intro to see a larger zoomed out pic. it might help.
Step 6: Inserting the Ram, Other Parts, and Firing
This is the final step. you simply add a few pieces (shown in pictures) and add rubberbands and fire. simple as that.
also- it shows what the ammunition looks like and how to load and fire it
Step 7: Finally
You are done! i will have a video up eventually. but i hope you enjoyed shooting and building this as much as i did.
have fun!
Step 8: Optional Step
MODIFY IT!
try to make it look like a real gun! or a gun from your favorite video game.
i tried to make mine look like the assault rifle off of halo 1:CE. i think it turned out well but could have turned out better if i had more pieces. so heres a few pics of it.
