Remote Control F-117A Stealth Bomber
2,875
29
5
Posted in TechnologyRemote-control
Introduction: Remote Control F-117A Stealth Bomber
I made this f-117A stealth bomber because I wanted a cool looking jet glider and I had some extra electronics laying around so I threw this together and i have had lots of fun with it. I made it with dollar tree foam, packing tape and hot glue.
specs.
  • wing span:44"
  • length:46"
  • high:8"
  • the longest flight was about 150' just throwing it
Step 1:
step.
  1. first you need to glue and tape the three peaces of dollar tree foam together
  2. next you need to draw a line down the center
  3. then you need to measure 14 inches down from the top
  4. from the 14 inch mark you need to draw a line down to the far corners
  5. then draw a line five inches from the bottom of the boards that is parallel to the bottom that is 10 inches long
  6. then take a ruler and make two lines from the edges of the 10 inch line and draw a inch up
  7. connect the corner of the wings to the top of the inch marks
  8. from the center of the 10 inch line draw a line one inch down
  9. connect the sides of the line to the new inch mark
Step 2:
  1. cut out your airplane
  2. take the scraps from under the wings and cut it in half
Step 3:
  1. take the peaces and cut and place so they fit nicely glue that down
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    5 Comments
    I would like to point out that the only recognized stealth bomber is the Northrop Grumman b-2 .
    How is this remote controlled in any way ?
    HELLO I NEED MORE DETAILED PLANS FOR GOOD able assemble. Thank you.
    Some words of advice- stealth black and avoid the trees!
    I put part of the plans but I am still working on the rest
