3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
remote control car fan
In this instructable I will show you how to put a fan for a cpu in a cheap electric rc car to keep it cool oh and by the way this is my first instructable.
Materials:9 volt battery connector Remote control car Cpu fan 9 volt battery and hot glue gun or tape or both.
Step 1Connecting the fan
connecting the fan
First connect the 9 volt connector to the fan wires I did this by just twisting the wires and taping them since I didnt have a soldering iron.Then find a place on the Remote control cars body close to the electric motor then hot glue it on the body.Make sure it dosent touch the body and it has to be high enough to get air on top of the fan
27 comments
Feb 28, 2010. 8:28 AMagis68 says:
Also you can make a hovercraft...maybe not remoted. You will use only the plastic cover of the car, close all the hols, plug the fan and enjoy it!
May 14, 2011. 4:32 AMVenemot says:
well first of all if you close all the holes there is no air for the fan to push downwards and by the way the fans used in pc's arent strong enough...!!!
Jan 1, 2011. 11:56 AM______ says:
What about the weight of the 9v battery?
Nov 22, 2010. 12:18 PMMudbud says:
hey I made a hovercraft with two xmods car curcuit boards!
Oct 8, 2011. 6:33 PMagis68 says:
You see!!! All you need is imagination and this brilliant community...
Jan 14, 2011. 9:34 AMilpug says:
this is cool. i dont see why it would need direct cooling like this unless you planned on driving it in the desert or something.
Feb 28, 2010. 12:17 PMHa4xor4life says:
This is a "ZipZap" Sold for 5 bucks at radio shack. This does not need ANY cooling, whatsoever.
Jan 1, 2011. 11:57 AM______ says:
Mine OVERHEATED so the fan is a good idea!
Mar 3, 2010. 4:27 PMWesley666 says:
Its not a ZipZap.  Those are way, WAY, smaller.  This is an X-Mod.  Way better because you can tweak alot more parts on them.  I enjoyed these when I was younger.  You can change them to front, rear or AWD, add lights, different motors, gear ratios, batteries, frequency, tires, heat-sinks, shock spring and ride height...  They are infinitely adaptable, and very hackable.  But sometimes they can get warm, especially with parts off EBay or AtomicMods.com...like the mythical, 100km/h motor!  This is actually a very good Instructable.
Oct 12, 2010. 8:53 PMLegofanatic says:
Not even an X-mod, This is a very cheap piece of crap rc that goes like 5 MPH. XD
Oct 14, 2010. 8:47 AMWesley666 says:
Yes, looking at the picture again, although it is about the size of an Xmod, the chassis looks like an Xmod, it has a different board and parts. I didn't look that close at it to begin with. My bad.
Nov 14, 2010. 11:10 AMzack247 says:
dont xmods have their battery compartments on the sides of the chassis? or am i thinking of some other car?
Nov 14, 2010. 6:41 PMWesley666 says:
The 1st gens do, the Evo series has them on the bottom.
May 18, 2011. 3:30 PMzack247 says:
i have found out the model of car used in this instructable, its the 2006 camaro concept from the "bigtime muscle" series from Jada toys, ive got one just like it.
its most likely the 1:16 scale version, but it could be the 1:14 scale version too.
Oct 14, 2010. 5:21 PMLegofanatic says:
LOL, np, Just wanted to point that out. XD
Nov 14, 2010. 11:07 AMjoeismydad says:
Ha i have the same car
Apr 17, 2010. 10:31 AMTSC says:
Nice!!!!!!!!!!!!!!!!!!!
Feb 25, 2010. 10:50 PMCoodude26 says:
 you mounted the fan against a flat surface...that's gonna do jack diddly squat, it has no air to pull in. also cars like this definitely don't need cooling
Feb 24, 2010. 9:38 PMthepaul1993 says:
To save on weight why not just run the fan off the card battery?
Nov 23, 2008. 7:06 PMlobo_pal says:
Does it really need a fan?
Dec 2, 2008. 3:48 PMQuickdraw says:
Some rc cars do. The only ones I see needing it though are high-performance electrics (Xmod, mini-z, Megapro, etc)
Aug 8, 2009. 9:10 PMcandle360 says:
I like this instructable, but that seems like it's geared more towards disposable RC's, I actually made a functional hood scoop for my xmod, and my E10 has never had any overheating problems. the only reason I made a hood scoop for the xmod was because I had a spare hood laying around, so I played around with it and made it look awesome. great instructable though
May 14, 2009. 10:57 AMrexnanet says:
Is the engine that overheats or the electronics? some aluminium or copper cooler would help to dissipate the heat, even in the engine but its a bit tricky to mount it. You should also get "fresh air" going inside the car or the fan doesn't do a lot... some holes in the bonnet? ;)
Mar 28, 2009. 5:47 AMda man says:
i had/have this car. it doesn't work anymore i don't think... i hooked up the same kind of 9v battery you used for the fan, instead of the 3aa's (tripple a's? i don't remember) it went really well. also i put tape on the wheels and drifted around a bit. spose if i had this mod the car would last longer...
Feb 12, 2009. 7:38 PMcarbon12 based says:
You only need this if the circuit gets hot. Now you have a fan, double the batteries for it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:murtledaturtle13
