3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
removable ironing-board top (on a cabinet)
Step 4Sew the Cover Pieces Together
Place the Cover pieces together (one of them now has the Batting attached) with the right sides facing each other, and the wrong sides out. Pin together.
Sew together all the way around leaving something like a 20cm (10 inches) opening on one of the sides to be able to turn it inside out. Press seam.
Carefully snip off outward corners, leaving a millimeter or two (1/16th inch) to the seam (see picture).
Carefully snip into inward corners, leaving a millimeter or two (1/16th inch) to the seam (see picture).
With the help of a pair of closed scissors at the corners turn the covers inside out.
Press the now turned out cover. Press the 20cm opening together as if closed. If you're like me, you'll hem it closed it with a small seam allowance (1/2 cm 3/16 inch) from the outside. You can also hand-stitch it closed with a hidden stitch.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:mirileh(miri's place)
