repair missing SD-card lock
 by zimmemic25
Step 3: Try it
insert into card reader. it should work, if not, try again.
Tips:
use 2-3 pieces of straw
try to make the new "lock" the same size the SD is. 1 mm more and it will stick in card reader.
waterlubber says: Feb 22, 2012. 8:38 AM
There is no button, although this will still work. In every SD reader there's an Optical Sensor, which checks for the switch. If the switch is in the unlocked position, it will trip the sensor. Putting the straw in blocks the sensor, so you can write to it again.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
