3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
repair/replace exhaust flange on catalytic converter (91 ford truck)
replace a rusty exhaust flange connector on a catalytic converter where it connects to the exhaust manifold. This will save replacing the entire catalytic converter as in this application the end of the pipe is flaired and/or in some applications the flange is spot welded to the end of the pipe.
Step 11 Parts needed, TWO exhaust flanges for the proper size pipe. (example #240880 EXHAUST PIPE FLANGES JC Whitney .com) 2 small Nuts and 2 small Bolts (sized by holes drilled later)
10 comments
Nov 16, 2011. 6:12 PMwatz528 says:
Exactly, to a T, what I was looking for, you are brilliant. Thanks for doing my homework. I owe you a coke.
Jul 12, 2011. 6:25 AMlongilandlou says:
Have not seen work like that in a long time. every one want's to weld. Good luck finding a sdud clamp.
Feb 17, 2011. 7:25 PMPower Tech says:
from reading this it seams to me that your calling the exhaust manifold or the Y-pipe the "converter"
dont do that any more.
Jan 18, 2008. 12:16 AMleebryuk says:
I like your do-it-yourself attitude. I truly appreciate it and I am a patron saint of the local salvage yards. However, I have learned to not touch exhaust systems. Call around your local small shops (NOT Midas, etc) and ask them how much it would be. I have broken more studs, skinned more knuckles, gouged out more parts of my hand and generally caused more bodily damage dealing with exhaust systems than I have with all other automobile work and sports combined. Thanks for letting me know about the JC Whitney Clamp-a-stud clamp. It's a trick part that will come in useful one day when I ignore my own advice :-)
Jan 20, 2008. 2:18 AMleebryuk says:
Chillax man...I said that you did a good job. I also thanked you for the trick studs from JC Whitney. I wear varying gloves (from nitrile to leather knuckle beasts.) Hands still slip every so often and I bruise something (fingers, wrists, forearms, elbows, etc.) That's what "bodily damage" means. Me and exhaust systems go way back and I don't care for working on them. I have to yank my engine from my Saab 900 to replace the front oil seal (for those who are not aware of the Saab magic, the engine is inline, but is ass backwards.) Some people can do it if they have thin arms. I don't have thin arms, more of a pop-eye look. So I have began the regiment of PB blaster a month ahead of time. That means I wait for the engine to cool down and soak the living h*ll out of every nut and bolt relating to the exhaust. I also have an impact wrench and will go to church before I attempt to loosen that first exhaust stud. And yes, repair shops will weld a new flange for you. Call a small one and ask around. Tell them what you want. Bargain a bit (can you help me with that price?). Don't show up in your sailing regatta hat. Bring some Gatorade with you as a thank you. You'll be surprised what a 12 pack of Pepsi will help you with. They can get a converter off in seconds, weld a replacement flange and have it on within another 10 minutes. Also, generic replacements abound for $40-60 nowadays. The moral of this story, play nice with your local small shops, show gratitude with cola, DIY and just relax as a whole.
Mar 20, 2006. 6:51 AMradiorental says:
clever hack
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:pmetro
