The hall sensor is a transducer that varies its output voltage in response to a magnetic field. Hall sensors are used for proximity switching, positioning, speed detection, and current sensing applications. Three phase BLDC motor has three hall sensors inside that are used for electric bike widely.
36V 250W brushless geared motor is popular in Europe, but in North America, people like 36V 750W hub motor more. More and more people order and enjoy these two types of DC hub motors that are called classic electric bike motors. Now they have received by most of customers because of good quality.
But when ride this hub motor bike and climb hill for a long time. Sometimes over current or over head will break motor controller's MOSFET or hall sensor.
Hall sensor is broken. The hub motor can't work. Unless your controller can drive sensor-less motor. Buy a new motor, cost more.
Replace hall sensor, cost less. Below we first instruct one type of 750w electric bike motor .
If hall sensor is broken, power on battery, you will find battery gauge works, horn works, lights work, everything is good, except when you turn your throttle, the hub motor wheel can't run.
Step 1:
Retest this hub motor and make sure it does be broken. Do you have voltmeter?
Still connect all wires and power on.
First measure 6-pin hall sensor plug, the voltage as below:
1.The voltage of red and black is about 4.5V;
2.The voltage of yellow and black is about 4.5V or 0V;(use hand to turn hub motor, the voltage will change from 0V-4.5V)
3.The voltage of green and black is about 4.5V or 0V;(use hand to turn hub motor, the voltage will change from 0V-4.5V)
4.The voltage of blue and black is about 0V or 4.5(use hand to turn hub motor, the voltage will change from 4.5V-0V)
If you can get above data it's no problem with bike conversion kit system. If the voltage of Item 2 (yellow and black wires)can't change from 0V-4.5V,Please replace this hall has a yellow wire connect.
You should prepare some tools and material:
1.Hexagon wrench (Necessary)
2.Hammer (Necessary)
3.Screwdriver
4.electric iron
5.A-B glue
6.insulated paper, insulated wire
7.scissors
8.New hall sensor
Step 2:
Take off nuts and gasket on axis and use hexagon wrench to loose 16 screws.
Step 3:
Make the electric bike motor stand and cable is bent inside. Left hand hold the hub motor and use hammer to knock the axis.
Step 4:
After some knock, the cover will take off hub.
Step 5:
Use the same way to knock the other axis, the other cover will also take off hub.
Step 6:
When both side covers are off hub, next we should take out the rotor-winding. Make the axis stands on the ground, both hands press hub motor, the rotor-winding will out of hub.
Step 7:
There are three hall sensor in three grooves around the rotor.
Use scissors to remove insulated wire and insulated paper. You will find 9-pin(three hall sensor)connect to PCB on rotor-winding. Each hall has three pin: 1:+ , 2:- ; 3:signal
For example:
Hall A: 1:+ , 2:- ; 3:Yellow wire
Hall B: 1:+ , 2:- ; 3:Blue wire
Hall C: 1:+ , 2:- ; 3:Green wire
Step 8:
Just now had known yellow wire hall sensor was broken. Please use electric iron to remove Hall A and use A-B glue to fix new hall sensor. Use insulated paper, insulated wire to fix PCB. Then re-build this hub motor.
Step 9:
Test as step 1.If can get the data from each hall sensor. Congratulate.
Power on battery, the hub motor wheel works.
Hub motor, BLDC motor, electric bike motor supplier: Leaf Motor Technology Co., Ltd
Website: http://www.leafmotor.com/
Step 1:
3.Screwdriver
4.electric iron
5.A-B glue
7.scissors
8.New hall sensor
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
For example:
Step 8:
Step 9:
Not Nice
Visit Our Store »
Go Pro Today »
