re(updated) Simple flyback driver
 by Alex McCown
Step 2: Winding the flyback
Grab your flyback and some of that mag wire and pliers and have a seat
Bend the tip of the wire a little bit and wrap the wire around the ferrite core (see the pics for help) 5 times for the feedback and 15-20 times for the primary and burn the tips with a torch or a lighter to burn off some of the insulation on the wire so your wires can get a good connection also dab some salder on the wire if the salder sticks you have a connection (see the pics)
if you want to use higher amps use thicker copper wire you only need 5 turn primary and 10 turn secondary
techno guy says: Jan 27, 2011. 7:35 AM
I tried winding a flyback like you said but the core is too close to this box thing on the flyback and I cant wind it so maybe you can tell me how to make it easier.
makincoolstuff in reply to techno guyAug 29, 2011. 3:23 AM
you could just get thinner wire, or you may have to find a different flyback if the core is to close to the "box thing" (i wonder what the box thing is called
Mahitchima in reply to makincoolstuffSep 6, 2011. 2:14 PM
You can use a round ferrite core with 2 windings, 1 in series with flyback primary. Or a transformator with 2 windings, just the same. =)
i use that on mine, and it works great.
codex653 says: Aug 3, 2009. 2:59 PM
why you using 300 amps??!?!?!?!
kikiclint in reply to codex653Aug 23, 2009. 9:33 PM
He probably meant 300 amp hours? Since that is a battery life unit.
Wargasm in reply to kikiclintMay 22, 2010. 5:35 AM
Yes, lol.
burrejus000 says: Sep 12, 2009. 4:20 PM
one thing is you don't need any blow torch or fire to strip a wire, thats what wire strippers are for, and solder is not spelled salder.
Bluexadema in reply to burrejus000Mar 24, 2010. 12:09 PM
you can use a lighter to strip enameled wire, its probably the most efficient but otherwise your right i would use strippers or a dike to pull of the insulation on standard wire
knoxarama says: Sep 29, 2009. 3:54 PM
does this look right?
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
