3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
rotate or pivot lcd monitor
This fixture is very usefull for rotate 90 degrees the monitor in order to see o read documents in in a portrait fashion, there are drivers for video card that support this modes, in my case i use it to read pdfs.
Step 1Materials and tools
materials and tools
  • E:\produccion\103NIKON\01r.JPG
  • E:\produccion\103NIKON\03r.JPG
  • E:\produccion\103NIKON\02r.JPG
Wood, 4 pieces, (1 column, 1 base, 2 pivots)
lazy susan or turn base,
4 screws for the monitor
3 metal angles
12 wood screws
screwdriver
17 comments
Oct 30, 2011. 8:31 PMNidht says:
Thanks for this guide! I did exactly this tonight and it took me very little time. I am loving having a portrait monitor next to my widescreen. =)
Sep 12, 2011. 10:59 AMlucashartmann25 says:
Where do I get one of the lcd monitor wall mounts?
May 19, 2007. 11:51 AMfelipenavas says:
There is any video driver to rotate the screen ?
Apr 24, 2008. 11:31 PMhobbyman says:
Windows XP also supports a rotated LCD monitor. All you need is to press a key combination before or after rotating the LCD.
Mar 31, 2011. 8:22 AMsigg3.net says:
On Dells this is: CTRL+Alt+Arrow keys
Dec 25, 2007. 6:18 PMramroids55 says:
There's No Need For A Driver, Most LCD's Can Rotate The Picture On The Screen By Either Going Into The Control Panel, Or In My Case Hitting Alt+Down..etc
Feb 3, 2009. 2:57 AMburnte says:
I'm thinking of doing the same thing. My question to you is does the bearing you have rotate freely, or does it have stop points, so that it takes a little effort to turn? I'd hate that a jiggle to the table could make it turn a little.
Jan 2, 2009. 8:45 AMbundito says:
Very good, very simple. Although I'm slightly unsure about the lazy-susan bearing like other have said, it's likely to work fine. You could always stress-test it by mounting one of the bearings and hanging weights from it until it fails... I suspect the failure point is much higher than the weight of an average LCD screen.
Sep 2, 2008. 6:50 PMsam_rocks321 says:
Too bad my dell 28 inch doesn't have vesa mount which Sucks... maby I can Jerry rig it! A Future Instructable!!!!!
Aug 5, 2007. 12:16 AMMurdok says:
I modded my monitor stand to get brackets and now my monitor is held to my wall by an old antennae (from a pair of broken "rabbit ears"), it is safe (knock on wood), easy, and cheap.
May 18, 2007. 7:03 AMTaotaoba says:
Very great instructable and comments. I gonna make one this weekend! Thanks a lot.
May 15, 2007. 5:18 AMterramonkey says:
ive spent the last 2 months designing and making a product that does exactly the same job as this for my college diploma, i concur with parman0 that the bearing you have used is not designed to hold a load in this plane and may fail without warning. in my design i overcame this by using an M10 screw through the two rotating plates and pre loading the thrust bearing in the rotational axis, however any method of fastening the two plates together whilst still allowing rotation should provide a safety net for your (expensive) screen should the bearing fail. i feel it would be only fair to post my version of this adaptor, and let you all give your criticism constructive or otherwise. (...windows users can normally rotate the screen image by using the keyboard shortcut.... Ctrl + Alt +(any direction arrow))
May 14, 2007. 10:46 AMparman0 says:
Be careful with the design. The lazy Susan bearing is designed for a load in the different axis. The two piece of casing may fail to hold and come off.
May 13, 2007. 5:37 AMadamazing says:
Where did you get the lazy susan bearing from?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:odrarek
