Introduction: Rotate or Pivot Lcd Monitor
This fixture is very usefull for rotate 90 degrees the monitor in order to see o read documents in in a portrait fashion, there are drivers for video card that support this modes, in my case i use it to read pdfs.
Step 1: Materials and Tools
Wood, 4 pieces, (1 column, 1 base, 2 pivots)
lazy susan or turn base,
4 screws for the monitor
3 metal angles
12 wood screws
screwdriver
Step 2: Attach the Pivotal Base
fix the pivotal base to the wood, previously make the drills for the screws of the lcd monitor,
the secuence of assembly:
1. the base to the monitor
2. the turn base o r lazy susan to the base 1
3. the base 2 to the lazy susan
4. the column to the system
Step 3: Fix the Column
fix the base and column with screws and the 3 angles
Step 4: Put All Together
screw the column to the pivotal base,
Step 5: The Pivot in Action
the monitor rotates with the fixture..
Step 6: Close Up of the Bearing Lazy Susan
Some views of the lazy susan used
