rubbing alcohol jet
 by nikdrtbkr
Step 4: Input piece from fan.
ok ur are goin to need to cut hole in the cap. once you cut the hole screw the cap on. Pull the two wires that are for the fan threw the cap.Then put the air tool fitting in the cap also. Glue everything on the cap to make it air tight.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
